Lightweight carpet options?
Old Feb 12, 2008 | 01:05 PM
tomcowle's Avatar
I did do a search but didn't find what I was looking for.
What is out there for lightweight carpet options? I have the factory black capet in my 1995 and oh my God is it heavy!!!
thanks!
Old Feb 12, 2008 | 08:44 PM
TedH's Avatar
I do not have a good answer for you on the weight issue but you certainly want to investigate the propeties of whatever you do in regards to combustion. When my car caught fire a couple of years back the stock carpet went up pretty quick and from what little I have seen of aftermarket stuff, you could greatly increase your chances of a fire if you are not extremely careful of your selection.
Old Feb 13, 2008 | 03:47 PM
You can save a few #'s off the stock carpet by removing the thick insulation mat from the back. There are light-weight options in aftermarket carpets.... have to try and find a link.
Old Feb 16, 2008 | 03:31 PM
rik89gta's Avatar
Im pretty sure Speed Inc. which is in The Chicagoland area offers lightweight carpet options. Go check em out.
Old Feb 17, 2008 | 12:38 PM
Z-RATED94's Avatar
Thanks for the tip. I'll look into that when I have my 6-point put in. Maybe from the front seats back would save me a few lbs.
Old Feb 17, 2008 | 02:56 PM
CamaroRacing12's Avatar
i ripped out all the carpet in the trunk area..... i have the sportsback so u cant even see it unless u open the trunk... i didnt weigh is but it was at least 5lbs
Old Feb 17, 2008 | 07:46 PM
ABA383's Avatar
I thought Speed Inc discontinued the light weight stuff, but I'm not sure...I just replaced mine with a new set from Year One who uses ACC...I left all the insulation on and it fits great...Its supposed to be a bit lighter than the stock stuff, but it felt pretty heavy...I'll tell you that the car is much more enjoyable to drive with the jute still on the carpet...Its almost quiet in there and I'm loving it...I had previously cut the back section of carpet out in the middle of the hump to save weight many stupid years ago and the car was always very noisey after that...As I get older I like the idea of quiet fast...
I've seen folks using the ozite stuff, but I'm not a big fan unless its a racecar...
--Alan
Old Feb 18, 2008 | 10:09 AM
T/A lt1's Avatar
I just installed the ozite carpet and I really like it, looks 10times better than old factory carpet and I glued it down real nice. Just google ozite. Later
Old Feb 18, 2008 | 10:29 AM
TedH's Avatar
JC Whitney?
Old Feb 18, 2008 | 09:20 PM
mod313's Avatar
Use the speaker box carpet. Clean off the entire floor then use a spray on adhesive to hold the carpet down. Patience and careful fitting will net you a clean install and a rug that ways a couple pounds instead of that heavy o.e. one. You can usually get it anyplace that does custom stereo installs.
Old Feb 18, 2008 | 11:04 PM
tomcowle's Avatar
I am down with that ozite stuff! They sell a few products that could work.
Thanks!
Ks0209
Oct 1, 2015 07:32 AM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
karpetcm
Sep 29, 2015 10:08 AM
