Launching
Old Jul 2, 2005 | 03:55 AM
00cls1camaross's Avatar
Launching
I have 2000 Camaro SS with an automatic trans. Does anyone know how to launch a car like this...like the way and how you shift
Old Jul 3, 2005 | 11:41 AM
MarkyMark's Avatar
Re: Launching
put it in drive and let the auto shift by itself. Basically you can either launch off idle, or press your brake and the accelerator stalling it up to around 1000 to 1500 rpms and take off from there. If you don't have drag radials I wouldnt go full throttle off the line, because most likely you will spin pretty good. Get the feel of the car, and you should start to feel how much gas you can give it at the start and still get traction. Once you do get traction you wanna make sure you go WOT as soon as possible.
Old Jul 3, 2005 | 07:19 PM
Re: Launching
thanks.... i have drag radials on my car but they are getting to the point where i need to replace them... do you have an automatic transmission?
Old Jul 3, 2005 | 09:50 PM
MarkyMark's Avatar
Re: Launching
Yea, I have an auto, I just basically stall it up as high as I can and I floor it off the line. I have Mickey Thompson drag radials and they dead hook every time. I really need a stall converter though, so I can cut some really decent 60 ft times.
Old Jul 4, 2005 | 08:46 PM
Re: Launching
have you changed your rev limiter at all?
Old Jul 4, 2005 | 09:14 PM
MarkyMark's Avatar
Re: Launching
well changing the rev limiter wont change the launch any, because once you go above between 1500-1800 rpms your tires will start to spin and you will probably lunge forward and get a redlight. My rev limiter was raised a little as well as my shift points.....they were done by madwolf (madz28.com)
Old Jul 5, 2005 | 11:54 AM
Re: Launching
i see... so now, how many rpms does your car shift at now
Old Jul 8, 2005 | 03:51 PM
pHEnomIC's Avatar
Re: Launching
Will you end up being faster if you launch at high rpms and spin the tires or roll into it and not spin them at all?
Old Jul 8, 2005 | 10:37 PM
MarkyMark's Avatar
Re: Launching
I got better 60 foots when I rolled into it, you gotta practice though and get on it as soon as you can.
Daluchman1974
Sep 11, 2015 06:12 AM
Critter
Jul 13, 2015 05:51 PM
Injuneer
May 15, 2015 08:45 AM
mark0006
Dec 25, 2014 09:50 PM
