launch techniques with m6
Old Dec 6, 2005 | 11:21 PM
NY99z28M6's Avatar
I have recently purchased a 99 camaro z28 manual and was wondering how to launch without doing too much damage. I dont want to perform all out drag launches but just how to launch in order to beat a ricer at a stoplight.
Old Dec 9, 2005 | 02:13 AM
camarorider's Avatar
Re: launch techniques with m6
This is my first manual car and all i can say is practice. Ive had it for a few months and im getting better all the time. Try reving to 2500rpm, thats a good starting point, or at least where i started from. Then drop the clutch and just let the pedal push your foot up. If you give it full throttle it'll just spin the tires, so i usually go about 1/2 to 3/4 until the tires stop spinning and then floor it.
hope this helps
Old Dec 9, 2005 | 02:55 AM
lt1Noobert's Avatar
You shouldn't have to launch hard to beat a ricer. However test different rpms like 2k 2.5k 3k ect. You'll have to try different rpms since it depends on your tires/road conditions. I wouldn't just dump the clutch tho. I try to step off of it quickly but smoothly instead of just all out dumping. You'll also have to feather the gas a little. It just takes practice.
Old Dec 10, 2005 | 01:05 PM
jmill96Z's Avatar
DO NOT SIDE STEP THE CLUTCH
You're gonna have to find out what works for your car. I launch at the strip at 5k on ET streets. On the street I'll feather the clutch a little to make sure I've got a clean launch. If you want to race ricers, just don't spin, you can afford to take it a little easy off the line so you don't spin through first
Old Dec 10, 2005 | 07:43 PM
MBonZ28's Avatar
dont you mean track?
dumping the clutch wont get you anywhere. its all about that balance between gas and clutch. practice is what it takes
Old Dec 13, 2005 | 11:04 PM
NY99z28M6's Avatar
thanks for the tips
Old Dec 14, 2005 | 08:18 AM
94z28jbw's Avatar
I've also noticed that if you let the clutch out just till you feel it barely hookup, then hit it, your plate will be moving approx. same speed as the flywheel. If you're stopped for a while, then cold launch, it may not be moving @ all, I'm sure you know what I'm talking about; double clutching [unessasary, it's not a semi-truck], but basically getting everything moving. [Somewhat like priming a pump.?]
Other than that......practice, practice, practice. [Especially your 2-3 gear shift.]
Daluchman1974
Sep 11, 2015 06:12 AM
mark0006
Dec 25, 2014 09:50 PM
Chicago94Z28
Sep 1, 2002 08:02 PM
97bowtie
Aug 25, 2002 11:00 PM
