Insight on my time slip plz?!
Old Apr 8, 2007 | 02:38 PM
1BadZ95's Avatar
Question Insight on my time slip plz?!
Well went to the track Friday night I was pretty pissed at myself. First off there was over 200 cars/bikes there so from 7pm to 11pm I only was able to do 3 runs. Second it was my first time ever at the track and I choked, my first two runs I missed 4th gear (I never do that), I think I may have bent a shift fork. Anyways, my last run I wanted to make sure I got it in gear so I grannyed it to 4th and 5th gear. The weather was about 55 degrees, about 30mph head wind, and 50% humidity. I also wheel hopped really bad through 1st and 2nd on this run only for some reason? I have relocation brackets and tubular LCA w/ poly bushings, and Nitto 555r's. What can I do to stop the wheel hop? Here's my time slip, what do you guys think my problem is? I know my car should be low 12's. Is it the granny shifting in 4th & 5th that hurt it that much ( I think I go into 4th around the 1/8)? 3415lbs w/ me.
60ft: 2.0071
330ft: 5.3680
1/8: 8.1882
1/8 mph: 87.5
1000et: 10.6198
1/4 et: 12.7000
1/4 mph: 108.46
Old Apr 9, 2007 | 08:44 AM
AL SS590 M6's Avatar
Moderator
Man all you need is some practice. You need to go to a non busy track and run 30 passes to get your ducks all in a row.
Old Apr 9, 2007 | 12:26 PM
godspeed1976's Avatar
Practice makes perfect. Something cheap that will help with the wheel hop some is a new torque arm bushing. I think Summit sells the energy suspension ones for $12. It will help, but practice will help much more.
Old Apr 18, 2007 | 09:35 AM
AlwaysCode390's Avatar
I installed a panhard bar and my wheel hop stopped ---
Old Apr 18, 2007 | 10:49 AM
Capn Pete's Avatar
Did you heat up the tires before you ran? With the DR's, it may help to warm them up a bit?
It's hard in front of a "crowd" like that though ... esp your first time at the track, and it's not like you're running a ~16-second Honda!! 12.7 is still pretty respectable . Practice, practice, practice doing HARD launches, trying to control wheel spin / hop, and shifting under full throttle. You can do better .
Old Apr 18, 2007 | 02:48 PM
1BadZ95's Avatar
Yea, I did pretty good 2nd gear burnouts. I know I can get quite a bit better. With 4.10's I should be trapping in 4th gear and that will help a lot!
To the guy about the panhard bar, I have a tubular adjustable panhard, LCAs, and Relo brackets. Since I went to the track weve taken off the torque arm, cut a slot in it, bent it, welded it back and reinforced it with a steel plate, I now have a little bit of - pinion angle. It's seemed to help the wheel hop on the street. I'll see next time I hit the track...
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
willie-d-nice
Feb 13, 2015 06:40 AM
centric
Aug 15, 2002 09:04 PM
