How much quicker?
How much quicker?
Hey guys right now I'm running apprx.2.0's 60ft and 13.4 1/4 times on stocker 16's they are doing alot of spinning of the line.Now my question is how much quicker would my times be when I purchase the Mickey Thomas street drags radials.
Re: How much quicker?
Mid to low 1.8 60s can be had and 13.dohs to 12.9999999999999999
Don't get your hopes up
. Problem is, once you put sticky tires on the car, they are just that ... STICKY. When I put DR's on my car (just BFG DR's) my mph slowed down by about ~1 mph, and my times were actually the same, or a few hundredths SLOWER than with the street tires!
Now granted, on that day at the track, conditions were perfect, and my tires were nearly brand new, so they were fairly soft and hooked really well.
In your case, with street tires that spin, you're losing maybe an extra ~tenth in the 60', but once you put DR's on the car, that will change things. Suddenly, your tires will hook hard, but then your motor will bog severely and won't have the power to pull you through 60' in much less than ~2.0 seconds. I had the same problem with my car EVEN WITH 4.10 gears!!
Realistically in your case, I'd expect (or hope for) ~1.9x 60' times, and ~13.2's +/-. But as well, conditions can really screw you over sometimes. I'm just saying this based on lots of experience with a pretty much "stock" LS1, just on different days and with different gears
What gears do you have, btw?
(2.73 or 3.23?)
Now granted, on that day at the track, conditions were perfect, and my tires were nearly brand new, so they were fairly soft and hooked really well.In your case, with street tires that spin, you're losing maybe an extra ~tenth in the 60', but once you put DR's on the car, that will change things. Suddenly, your tires will hook hard, but then your motor will bog severely and won't have the power to pull you through 60' in much less than ~2.0 seconds. I had the same problem with my car EVEN WITH 4.10 gears!!
.What gears do you have, btw?
(2.73 or 3.23?)
Realistically, with 2.73 gears, I would be expecting 1.9 sixty foot times with good tires on a good track in good air. Now if you do a decent 2800 stall and even some 3.42s or 3.73s you will be able to use the sticky tires to hook up well. At 104 you are around the 13.0 +/- mark depending on the day. If you are spinning you can't really quanity the results of any changes to the vehicle so tires would be a very good thing to do.
Originally Posted by Shon Herron
I know there is more than a tenth in the 60' with sticky tires.
dr's with 2.73's 2.3 60' 13.2@ 112
dr's with 3.73's 2.0 60' 11.87@ 118
I'd like to think it would be better than a 13.4 @ 104??
