How much quicker?
Old Jul 6, 2006 | 06:58 AM
black02z28's Avatar
How much quicker?
Hey guys right now I'm running apprx.2.0's 60ft and 13.4 1/4 times on stocker 16's they are doing alot of spinning of the line.Now my question is how much quicker would my times be when I purchase the Mickey Thomas street drags radials.
Old Jul 6, 2006 | 08:27 AM
Shon Herron's Avatar
Re: How much quicker?
a tenth in the 60' is about 1.5 in the 1/4, typically that is what we have seen.
Old Jul 6, 2006 | 08:29 AM
AL SS590 M6's Avatar
Moderator
Stick or auto? What's your MPH?
Mid to low 1.8 60s can be had and 13.dohs to 12.9999999999999999
Old Jul 6, 2006 | 08:55 AM
black02z28's Avatar
Auto and my MPH were 104.87.I'm hoping 12.9'ssssssssssss
Old Jul 6, 2006 | 09:13 AM
myslowcamaro's Avatar
you probably will see 12.9-13.0
Old Jul 6, 2006 | 10:00 AM
black02z28's Avatar
Wow about a half second faster that's what I was hoping Thanks guys..Oh who has the MT Street Drag Radials cheapest?
Old Jul 6, 2006 | 01:28 PM
Capn Pete's Avatar
Don't get your hopes up. Problem is, once you put sticky tires on the car, they are just that ... STICKY. When I put DR's on my car (just BFG DR's) my mph slowed down by about ~1 mph, and my times were actually the same, or a few hundredths SLOWER than with the street tires! Now granted, on that day at the track, conditions were perfect, and my tires were nearly brand new, so they were fairly soft and hooked really well.
In your case, with street tires that spin, you're losing maybe an extra ~tenth in the 60', but once you put DR's on the car, that will change things. Suddenly, your tires will hook hard, but then your motor will bog severely and won't have the power to pull you through 60' in much less than ~2.0 seconds. I had the same problem with my car EVEN WITH 4.10 gears!!
Realistically in your case, I'd expect (or hope for) ~1.9x 60' times, and ~13.2's +/-. But as well, conditions can really screw you over sometimes. I'm just saying this based on lots of experience with a pretty much "stock" LS1, just on different days and with different gears.
What gears do you have, btw? (2.73 or 3.23?)
Old Jul 6, 2006 | 01:33 PM
I know there is more than a tenth in the 60' with sticky tires.
Old Jul 6, 2006 | 08:13 PM
black02z28's Avatar
2.73's
Old Jul 6, 2006 | 09:34 PM
TedH's Avatar
Realistically, with 2.73 gears, I would be expecting 1.9 sixty foot times with good tires on a good track in good air. Now if you do a decent 2800 stall and even some 3.42s or 3.73s you will be able to use the sticky tires to hook up well. At 104 you are around the 13.0 +/- mark depending on the day. If you are spinning you can't really quanity the results of any changes to the vehicle so tires would be a very good thing to do.
Old Jul 7, 2006 | 07:55 AM
Capn Pete's Avatar
If he's already cutting ~2.0, that's pretty good for street tires and 2.73 gears. Slap on some sticky tires, 1.9's are probably realistic for that setup, but I wouldn't expect to see 1.8's. Not w/2.73's, not with a relatively stock LS1. Like I said earlier, even with 4.10 gears, my car bogged pretty bad off the line when I got good traction (no wheel spin whatsoever). By spinning the tires with 2.73's, at least it gets the engine revving up into the power band a little more. Hook the tires hard though, and the revs won't get up as quick, and I don't think the times will improve as much as you might think. JMO.
Old Jul 7, 2006 | 08:03 AM
black02z28's Avatar
Oh and BTW my best was 1.88 60ft with stockers and 2.73's...
Old Jul 7, 2006 | 08:13 AM
Capn Pete's Avatar
What was your 1/4 time & speed with that 60' then?? I'd like to think it would be better than a 13.4 @ 104??
Old Jul 7, 2006 | 04:03 PM
just my own experience 420rwhp
dr's with 2.73's 2.3 60' 13.2@ 112
dr's with 3.73's 2.0 60' 11.87@ 118
Old Jul 7, 2006 | 07:44 PM
slomarao's Avatar
if you cut a 1.88 60ft and only ran a 13.4 @104 something is wrong with you car. You need a tune up more then dr's.
