How much more do I need to run High 12's
Old May 7, 2008 | 02:49 PM
fastdan's Avatar
I have a 93 Z28 with a 96 Trans Am Engine only 30,000 miles.
It's an A4.
My Mods are:
K&N Cone filter
Hooker Long Tube Headers
No Cats
True dual 3 inch Exhaust
3000 Stall Torque Convertor
Ecu I think. My car shifts at around 6000
3:23 Stock Rear
CSR Electric Water Pump
Removed Egr and Emissions
TB Bypass
Slight weight reduction
I never actually ran the car.
Let me know what you think.
Thanks,
Dan
Old May 7, 2008 | 02:58 PM
tomcowle's Avatar
3.73's and a good tune and you'll be flying.
Old May 7, 2008 | 04:15 PM
LSWHO's Avatar
With drag radials you might do it now.
Otherwise I'd agree with above.
Old May 7, 2008 | 11:04 PM
rock1501's Avatar
I agree I ran 12.52 with what you have and et streets and 373 gears
Old May 7, 2008 | 11:22 PM
CamaroRacing12's Avatar
if u have sticky tires ur in the 12's
Old May 8, 2008 | 06:28 AM
AL SS590 M6's Avatar
Moderator
I agree.
Old May 8, 2008 | 06:50 AM
JakeRobb's Avatar
Super Moderator
Practice, guys. He'll need practice.
Old May 8, 2008 | 09:20 AM
Z-RATED94's Avatar
What brand converter? As far as sticky tires, try a set of MT street radials. I think you'll like em.
Old May 8, 2008 | 12:04 PM
northdakota93z28's Avatar
skip 12's run a 150 shot!!!
Old May 8, 2008 | 01:26 PM
yea u wont get 12's first pass... but after a few trips to the track with sticky tires u will be in the 12's
Old May 9, 2008 | 07:11 AM
Moderator
Oh come on Jake it's an automatic. A4 + sticky tires = no practice necessary. Heat the tires up, stage, stab the gas, stop and collect 12 second time slip.
Old May 9, 2008 | 12:39 PM
slomarao's Avatar
you should be able to get there with what you have provided you cut good 60ft times. If you cant 60ft now you ll b able to with a set of dr's.
The 3.73's will get you there even if you 60's suck.
What kind of weight reduction? How much? Getting your race weight down will help everything out across the broad.
HectorM52
Jun 23, 2016 08:42 PM
Jan 23, 2015 01:13 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
