How long stock 10 bolt will last?
Old Jan 7, 2003 | 04:15 PM
dobe's Avatar
Just got my car back together and wanna run at the track maybe a total of 10 times this year at most...
Got a set of 26x10 et streets a friend said he would let me use. My question is will the stock 10 bolt hold up if I don't heat the tires real good and let it spin out of the hole a little?
3.42 gears, 373 lb tq, 395rwhp
thanks
Old Jan 7, 2003 | 04:38 PM
kazman's Avatar
IMO with your mods and ET streets I can't see how your not going to break the rear. Hope that I'm wrong. Good luck.
Old Jan 7, 2003 | 05:17 PM
96speed's Avatar
Depends on how you drive. Slip the clutch a bit and be easy on the shifts and you might be ok for awhile. Any kind of launch or power shift and I'd have a cell phone handy. M6 + ET streets is asking for it. M6 + DRs is a gamble. M6 + street tires will let you drive home.
I wouldn't waste a 10-bolt on purpose...but I'm poor .
Ryan
Old Jan 7, 2003 | 06:21 PM
dobe's Avatar
Thanks, maybe I will just keep it on street tires and save for a 12bolt. Bad thing is already saving for a new bottom end
any est. what i'll run in the 1/4 mile? more then likely on street tires i can only get a 2.1 60' at most
thanks for the responses
later
Brian
Old Jan 7, 2003 | 07:58 PM
Derrick Redd's Avatar
With a 6 speed I don't even think drag radials would be that safe. Auto's on the other hand..................
Old Jan 7, 2003 | 08:11 PM
mod313's Avatar
Granted mine is an auto but it does hit tires pretty hard. Mine has lasted 2 full seasons. My 60' times are pretty consistantly in the mid 1.5's. My conv is an ATI treemaster 8" and flashes over 5k on launch. With good clutch technique I suspect you should be ok for a few passes. Same motor was in this before the auto went in and I had no trouble with mine even with the higher rpm launches.
Old Jan 8, 2003 | 10:36 AM
96speed's Avatar
On street tires you might run low 12s around 115-118ish depending on your raceweight, weather, etc...
Ryan
Old Jan 8, 2003 | 10:51 AM
GREGG 97Z's Avatar
Ryan
I'm running DR's with the stock rear and M6 and everytime I run I figure it's a bit of a gamble, I would love a 12 bolt but it's just not in the budget right now. I wouldn't feel safe launching hard on ET streets with the M6 though, that is really asking for it My rear has held up fine so far with DR's and 4:10's, about 30 passes this year. If you are going to stick with the stock rear I would recommend getting the bearing cap stud kit along with a rear support cover like the TA that has the preload studs. It's not going to make it bulletproof by any means but it does help some.
Also I definitely think a stock rear has a lot better chance surviving hard launches if you have a stock or stock type clutch. I'm using SLP's, it's a stock disc and the LT4 PP. It grabs much better than stock but it's nowhere near as hard as some of the more serious clutches like the street twin. I would be a lot more worried about the shock the stock rear would take with a clutch like that.
Old Jan 9, 2003 | 05:43 PM
SAR2K's Avatar
Aslong as you don't plan on many hard launches you should last a good while. If you up the gears and start leaving harder... might as well up grade the rear.
Steve...
Old Jan 9, 2003 | 06:03 PM
COMNBYU's Avatar
people automatically look at the stock 10blts as weak. this is not so. they can be made to be just as strong as a 12. and if your on a budget like so many of us are, its the smart thing to do.
the situation you are encountering now is the reason i didnt get a M6 car. i know the first thing i would have done is put on some slicks and dumped the clutch at 5k+. the autos arent quite as hard on the rear.
i would get a girdle, good axles and a strong posi, and you should be fine.
Old Jan 10, 2003 | 03:05 PM
rpm4lalo's Avatar
I just had my Motive 4.11's put in my M6 TA and had the mechanic also put in a Ratech Solid Pinion Spacer. I also have a Summit Aluminum Support cover and a Zexel Torson Carrier. I run Nitto Drags with the SLP clutch kit. i am still fearful it will break sooner than later, so I am saving up for a 9 inch.
Old Jan 11, 2003 | 09:01 PM
jonaddis84's Avatar
If anyone is still reading this. Exactly what happens most of the time when you "break the rearend", does it become totally useless, or do you just need a new ring/pinion. Always wondered this.
Old Jan 11, 2003 | 09:15 PM
I'd say the most common thing is gear breakage. There are other things that can break such as the posi or the axles themselves. I've only had to replace 1 set of gears in 3 years. (knocks on wood)
Old Jan 12, 2003 | 10:50 PM
automec's Avatar
i just installed moser axels, t/a girdle, eaton posi. and 4.11 gears and have et streets .but only have a couple of cold (25*) runs on them. and am installing a pro race fogger next month . im hoping it wil hold up
mike
Old Jan 14, 2003 | 02:52 AM
chesee48's Avatar
yep, looks like u need to start saving for a moser or simlar
nice numbers BTW
