help a newbie out
Old Apr 17, 2007 | 10:13 PM
z28luva's Avatar
help a newbie out
im going for my first trip to the track this weekend and need a few pointers. dont know much about racing but my car is built for it. 74 cam z28 with a 396. what are some of the basics i should know? some tips?
also quick question. is it a good idea to rev the engine alot with the clutch down and try and start from 2nd or 3rd gear? will that help my starting speed any?
please share any info you want. anything is appreciated. thanks guys.
Old Apr 18, 2007 | 07:19 AM
cnorton's Avatar
Launching in 2nd or 3rd gear will fry your clutch. Do not try it. Experimentation will be required to find the exact RPM in 1st gear that will turn the tires without bogging the engine. Feathering the throttle from that point until you find the hook point will produce the best times.
There are several do's and don'ts that are connected with drag strip participation. Before taking your car to the staging lanes, make sure that you've checked out the turn-offs so that you know which direction you need to go at the end of the track to get back to the pits. I suggest that you also go to the starting line area ahead of time and carefully watch other cars as they're pulled forward from the staging lanes to the waterbox and then as they approach the staging beams.
When you've seen how things are done, get into line, STAY WITH YOUR CAR as you're waiting for your line to move. Decide on the best burnout procedure for your car's tires and suspension. After the burnout, move forward very carefully as you approach the beams. Light the pre-stage bulb, roll forward slowly until the full-stage bulb is lit. At the point that you have lit the second bulb, be ready to go.
Have a good time.
Old Apr 18, 2007 | 08:11 PM
z28luva's Avatar
thanks for the advice. any technique tips you care to offer?
Old Apr 18, 2007 | 10:07 PM
cnorton's Avatar
You have a PM.
Old Apr 18, 2007 | 10:58 PM
bombebomb's Avatar
Remember the beams are not at the tree, there quite a few feet behind the tree. Since iv never went to one yet, thats all I can tell ya :P
Old Apr 18, 2007 | 11:30 PM
CamaroRacing12's Avatar
leave on the last yellow bulb for best R/T
Old Apr 19, 2007 | 08:27 PM
RicocheT's Avatar
I've seen many people stage with the rear tires.. It really helps their 60ft times
Z28countrymama
Jan 22, 2015 02:50 AM
ssz28
Apr 29, 2003 05:26 PM
greg biz
West North Central
Apr 25, 2003 01:00 PM
lastZ
Jan 12, 2003 05:29 PM
2000zee28
Jan 11, 2003 09:57 PM
