Help me decide tires for the front
Old Jul 26, 2010 | 04:08 PM
RedHottG2's Avatar
On the back I will be running Weld pro stars..15x10 with 7.5" BS w/ Mickey Thompson 275/60R15 ET Street Radial.
Now on to the front, I'm going to use Race Star 15x3.75 with 1.5” BS.
What front tires should I run to look right with this set-up ?
M/T sportsman 26x7.5x15's OR M/T 26.0/4.5-15 ET Front
My car is not a d/d but does see some street use but only goes fast straight. I don't take corners, hell I don't even have a front sway bar anymore. The car see's more track time then street. I just want to make sure what front runner tire is going to look the best with the back set-up for when it does hit the street. Thanks!
Old Jul 26, 2010 | 07:34 PM
AL SS590 M6's Avatar
Moderator
I run 185 x 15 radial (VW size) on mine. No Problems at all.
Old Jul 28, 2010 | 05:36 PM
RedHottG2's Avatar
I've decided to go with M/T Sportsmans for the street.
Now do I need do I need standard or ply ?
http://www.byunspeed.com/product_inf...oducts_id=3385
http://www.byunspeed.com/product_inf...ducts_id=11463
Also I see the M/T 275/60R15 ET Street's are available in a 26" and 28" size. Which would be better for me to use ?
http://www.speedinc.com/catagory.cfm...ls%20/%20Tires
Also for the record I'm going with Billet Specialties Street Lite's front and rear.
http://www.billetspecialties.com/ite...d=251&pid=1027
Old Jul 31, 2010 | 09:28 PM
The M/T Sportsman Front is a bias ply tire. You shouldn't use a bias ply tire in the front and a radial tire (ET Street Radial) in the back. What little handling you might have with race tires on the street will be reduced to dangerous levels.
carguy0119
Apr 11, 2016 11:11 PM
CARiD
Feb 9, 2015 09:35 AM
ModdedNerd
Dec 25, 2014 05:51 PM
Hurin
Dec 13, 2014 07:38 PM
