Got a baseline- 10.82@127.97
Old 05-30-2009, 10:04 AM
jonesy's Avatar
went to Martin Mi. last night to get a baseline before I added my Wolffe drag swaybar. 1.61- 60', 6.96@101.60 1/8, 10.82@127.97
my suspension is stock swaybar( soon to be gone!!)
Spohn torque arm & lowers
QA1's all way around
I was only able to make 2 passes due to the fact ton of people getting ready for Pinks Allout Qualifier. my goal is 10.50's and with dropping 60' time should get there. M6 car launching @ 4800
adding Wolffe swaybar and wanted to compare stock vs aftermarket, plan on going to track next week will post results again
jonesy is offline
Old 05-30-2009, 10:22 AM
mdacton's Avatar
10.50's will be a breeze......
Work the suspension and get the 60' in the low 1.40's It will go faster.....
Whats you engine program?
mdacton is offline
Old 05-30-2009, 06:05 PM
jonesy's Avatar
forged and splayed( LT1) 350, self ported heads( 2.02/1.60), 1.7 rockers, 58 mm tb, GM 847 cam, Speed Inc tune, Hooker long tubes,3.89 gear (9")m6, and going through full Magna Flow ex.
jonesy is offline
Old 05-30-2009, 06:06 PM
jonesy's Avatar
and spraying 150 shot
jonesy is offline
Old 06-01-2009, 05:30 PM
AutoRoc's Avatar
How does it leave? IS there a bog/dead hook or tire spin? Can anyone watch the tire for you and report back? Front end action also, does it rise and fall sharply? Not at all? Does it rise and stay up? I don't think I ever seen your car or video. launch rpm doesn't sound too timid. Does it spray at WOT, when the clutch is dumped, or is there an rpm window?
Sounds mean though! I'm shooting for mid 10's also at PINKS.
AutoRoc is offline
Old 06-01-2009, 08:21 PM
jonesy's Avatar
tire spin, left front up about 8", right about 4", why I'm adding Wolffe swaybar, spray is on WOT.I have a window switch but bypass it when at the track
jonesy is offline
Old 06-01-2009, 09:10 PM
AutoRoc's Avatar
Should have came to Milan for the sat. morning track rental. Looked worthwhile from the pics.
No idea... sounds cool! haha
I wonder if there is some ET to shave in the 1-2 shiftpoint? More or less rpm or is it so fast that you're just happy to get a clean 2nd whenever? I'm guessing you shift at or before the 60'.
AutoRoc is offline
Old 06-01-2009, 10:30 PM
97 RedSS's Avatar
What gear/tires you running? I'm scared to spray out of the hole...lol. Hope you have a nitrous rdy DS! Great runs tho!
Cody
97 RedSS is offline
Old 06-02-2009, 07:02 AM
jonesy's Avatar
3.89 gears, 26" ET Streets @ 12 lbs ( 26-11.50-15), I have my shift light set@ 6800, if swaybar doesn't do the trick, switching to 4.33 and 28's, still think I can cut 1.4's with the tire I have, just need to tune and find a happy launch rpm. have less than 12 passes total since I got the car done last year, hurt a few fealings on the street though!! license plate says" C-YA GT " love the Ford guys, especially my brother and his GT buddies
jonesy is offline
RamAir95TA
12-16-2010 10:09 PM
T/A lt1
04-09-2010 11:59 AM
T/A lt1
11-27-2009 07:55 AM
taner
09-28-2004 05:46 AM
Quick Reply: Got a baseline- 10.82@127.97
