going to Kinston Drag Strip on thursday. need better times
Old Apr 5, 2011 | 08:30 PM
30th_ANNIV_Z28's Avatar
I have about 1/4 tank of 87 gas and im trying to empty it tomorrow with all the running arround i have to do. will using 92 change the results in a 1/4 mile from when i was using 87? If so about how much of a change you thing it will be.
Kind of a stupid question...i know but i wanted to ask the ones who know best.
thanks
Old Apr 6, 2011 | 10:05 AM
Z28SORR's Avatar
Re: going to Kinston Drag Strip on thursday. need better times
If the 87 octane causes a "knock retard" in the timing, then yes it will help. If it is NOT causing timing to retard then it may actually slow the car.
But I doubt that even under controlled conditions, at a track, you would be able to tell.
Old Apr 7, 2011 | 07:10 AM
AL SS590 M6's Avatar
Moderator
Could be a couple of tenths.
Old Apr 8, 2011 | 06:15 AM
i think the 93 helpped cause i dropped my time down to a 14.18 and i my slowest time was a 14.39. and my top speed went up to 96.4. and that was out of 9 runs.
Old May 23, 2011 | 10:15 PM
Black_Z's Avatar
If you want to make a big difference, focus on air into the engine and air out of the engine. I ran 14.1 all day and did the following low budget big improvement mods:
1) Hooker long tubes, 3" y-pipe and flowmaster american thunder cat-back
2) Moroso cold air induction
3) B&M ripper shifter
4) MSD 8.5mm wires and bosch platinum plugs
Before: After:
60' 2.148 60' 2.120
330' 5.973 330' 5.697
1/8 9.106 1/8 8.624
MPH 78.59 MPH 84.59
1000 11.772 1000 11.136
1/4 14.024 1/4 13.255
MPH 101.24 MPH 106.89
Before and after was on street tires. BG Comp T/A 245/50/16
I have since went deeper into the engine and still working on the suspension to get it to stick.
Old May 23, 2011 | 10:25 PM
calaban's Avatar
Man, I really got to get my 60' times down. The first and only time I went my time was with a CAI, Flowmaster replacement muffler, TB Bypass, Air Foil, 160 T-stat only my timeslip said:
Reaction: .157
I1: 2.506
I2: 6.494
I3: 9.722
MPH: 76.418
ET: 14.835
MPH: 96.396
M.O.V 1.525
This was an evening in August 08 that was 85* and I had tires that wouldn't stick to anything. The 60' shows that.
My speed was good, just need to nail the launch. I've added sfc's since as well.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Moshbmx1
Jan 20, 2015 03:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
