flash or stall?
I brake torque mine to 1200 rpm with the et streets any higher and it seems to bog .but with dragradials I seem to get better 60 fts(best 1.66)with bringing it upto about 1800 on the brake.I guess every setup is different
goodluck
Dave
96z,A-4, k&n cai,373gears,mack headers,highflow cat,3inch cutout, flowmaster catback,crane 1.6rr`s,crane dual valvesprings,underdrive,LT4KM,hpp,tb bypass,3000 vigilante,transgo,et streets.suspention is totally stock
best time slip(BOLTON) 60 foot 1.704 1/8 mph 85.37 1/8 et.8.044 1/4 mph 105.89et 12.654
cc305 cam,pcmforless programming
best time with cam(corrected)12.29@110.21mph
goodluck
Dave
I brake stall mine as high as I can get it at the line(2,400-2,600) and let it rip!
1.65 60ft
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
1.65 60ft
Ellis
Team Captain
www.teamnwfbody.org
I launch at 1100. Consistentlow 1.6 sicty foot times and the drivers side front tire yanks up pretty well.
'94 Black Z28, 383, 700R4
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
1/8 ET: 7.49
1/4 ET: 11.86
1/4 MPH: 112
EXPERIMENT!! No ones combination is the same!
What works for me may not work for you. Let your ET slips give you the info to decide what your car likes!!
---God Speed, Good Luck and Fast Times to You!---
Kevin Hinkley (HInk) * '94 T/A GT * Best Numbers: 11.952 * 116.83 * 7.566 * 90.51 * 1.579 * Naturally Aspirated 350 ci LT1, No Nitrous, No Blower, No Turbo(s)... Just GOD's good, cold air and gobs of money!
FORMER:
IHRA Bracket World Champion and runner-up
IHRA Bracket World Champion.
NSCA/NMCA EFI Eliminator #6902 Sponsored by:
THUNDER RACING * BMR * DETROIT SPEEDWORKS, INC. * MEINEKE MUFFLER, Jackson, MI. * DISCOUNT TIRE, Jackson MI *
Thank you to all sponsors for your kind help and knowledge!
FORMER:
RedBird is right every car is different. I launch my 69 at 4500 off foot brake for best 60ft times of 1.52 7.0s in the 1/8th. One buddy leaves at 1300 in his 68 camaro and has consistent 1.62s, at 7.4s in the 1/8th. another in his 68 Bird leaves off tansbrake at 4200 and is in the 1.38-1.40 range, at 6.3 in the 1/8th. so as you can see not every car is not the same. just go out try different ways and rember have FUN!!!!
Steve
69 Camaro 355ci, Dart Pro-1's, Flowed by CFM. Solid Roller 6" rods 13.2-1 Comp Turbo350 Trans 4700 stall.4:88 gears 29" Slicks or MH RaceMasters on the street
Steve
Couple of more considerations:
1) A lot of converter makers say flashing the converter will net higher stall speeds.
2) Bringing the converter up against the brakes at higher RPMs :
a] Builds A lot of heat.
b] Builds heat very quickly!
Personnely, I leave at maybe 1200-1300 RPM, just enough to load the drivetrain.
FORMER:
[This message has been edited by Redbird (edited August 16, 2002).]
FORMER:
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
