First time out with my 98
I bought the car wrecked and fixed it. I put a nitrous kit 125, and LCA from my LT1 car on it. I bought a lid and got some flowtech headers. I ran it with the airfiler and all. I was running ET streets and skinnies on the front.
The car bogged out of the hole I guess from the stock convertor and gears. I let it roll out a bit and hit the juice. She took off. I got my slip and heres what it said.
60 ft 1.8219
1/8 et 7.6414
1/8mph 91.89
1/4 12.0844
1/4 mph 112.19
I had to let off a little at the end because my windows fogged up and I couldnt see. I only got 2 runs in. My second run I tried to spray it sooner to keep it from bogging and she burped. But I did manage to pull the front wheels about 6 inches. I think it runs pretty good for just a few mods.
This was at Fayetteville last night.
60 ft 1.8219
1/8 et 7.6414
1/8mph 91.89
1/4 12.0844
1/4 mph 112.19
Re: First time out with my 98
a little bit yea.......enough that you cant see and have to let off....no. It is a very fast time, but saying that you had to let off because your windows fogged up to try and make us believe your car will go faster than it really does is stupid.
I believe it is faster. I wouldnt call BS unless you seen. I had to let off it. I was real impress with the LS1. I had alot of engine in my LT1 and I could only get it to run 11.0s. So calm down go take your medicine. Its Ok to be jealous. LOL
hehe......I dont doubt your car is fast or the time you ran.....and I'm sure you have more in your car and possibly 11's, but I was just doubting the whole let off thing cause of fog..........but it is all kinda silly so I will squash it and say Nice run man!
you pulled the front wheels off the ground with a 1.8 60ft? my friend has a 98 and he pulls 1.66 60ft with a 3500 stall, and his wheels don't come up at all.
his suspension is stock exept for !sway bar and poly control arm bushings.
im' comfuz'd
edit: btw, his car runs 11.5
im' comfuz'd
I've had mine fog up that way. Real humid day then night hits and the temps get near to the dew point. If you have the HVAC on then the incoming air can fog the inside of the windshield fast. I now run with the HVAC in the off position and it hasn't happened since.
im' comfuz'd
im' comfuz'd
ChrisFrez
Feb 1, 2015 08:26 AM
