First runs with 02 SS...
Old Sep 7, 2002 | 11:12 AM
brtrlyrdls1z28's Avatar
Post First runs with 02 SS...
The car has 4k miles on odometer and mods in sig.
Times are as follows:
1st run:
R/T....784
60'...2.032
330...5.716
1/8...8.665
MPH...83.88
990...11.143
1/4...13.377
MPH...104.62
2nd run:
R/T....840
60'...2.057
330...5.679
1/8...8.593
MPH...84.69
990...11.051
1/4...13.268
MPH...105.37
Times were at Atco Raceway, NJ. I'm hoping if I get some more miles on the car and run it in nice cold weather, it'll do 13.0x-12.9x like my 00 Z28 did with the same mods. Oh well, time will tell.
Ben
02 SS
coupe, loaded, auto, 3.23
sebring silver metallic
K+N, SLP lid, Magnaflow muffler w/3" tails
[This message has been edited by brtrlyrdls1z28 (edited September 07, 2002).]
Old Sep 8, 2002 | 07:29 AM
GJE94Z28's Avatar
Talking
Those are some really nice times, especially for a automatic. Actually, that's the best i've seen a auto run. I seen alot of stock 02 SS 6 speeds and only a few have hit those numbers. Again, nice job. Is there a stall converter in your near future?
94 A4 Black 3.42 gears
160 stat
CSI elec. water pump
LT1 edit
Hot cam
K&N CAI
March crank pully
K&N air foil
MAS port/polished
LT4KM
Edelbrock headers 1 5/8.
Crane Gold 1.6RR
Stock Coil
MSD 6A
Vigilante 2800
Transgo shift kit
Best 60ft: 1.76
1/8 ET: 8.15 @ 85.07
1/4 ET: 12.80@105.88MPH
Old Sep 8, 2002 | 01:58 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by GJE94Z28:
</font>
Thanks. Yeah...I think when my warranty runs out I'll probably get a higher stall converter. It's probably one of the best mods you can do to an auto.
Ben
02 SS
Best 1/4: 13.26 @ 105.37 w/2.057 60'
Best 60': 2.032
[This message has been edited by brtrlyrdls1z28 (edited September 08, 2002).]
Old Sep 8, 2002 | 05:44 PM
Fred94LT1's Avatar
Post
Ben, why the new car? I guess you beat that 2000 all you dared to. It was real quick though for what little you did to it. I just ran a 2002 Z28 6 speed car at Atco and he could only get a 13.6@102 on a 2.1 60' time. He has an HPP and cold air intake. Damn son you can drive.. Lets see what that beast will run with a proper 3600 converter,
Fred
1994 Z28, A4,
BEST 1/4 12.413@109.55
BEST 1/4 MPH 110.49
BEST 60' 1.668
BEST 1/8 7.884@86.35
BEST 1/8 mph 86.77
Race Weight 3600lbs
No new times with P&P heads Flow 239.4 INT 182.1 @525 lift, or
24lb SVO inj's...
Old Sep 8, 2002 | 10:04 PM
Post
Hey Fred. I totaled my Z in May. So I went out and got an SS. I do miss how well the Z ran. I hope this car runs just as good. It seems to be good so far. Hehe..with a 3600 stall it should do high 12's all day easy. I'm sure I'll be shopping for a converter and/or gears when the odometer hits 36,001 .
Ben
02 SS
Best 60': 2.032
Old Sep 11, 2002 | 08:45 PM
Fred94LT1's Avatar
Wink
Ben, I'll guarantee you will hit 12.9's this fall. What was the date when your 2000 Z28 went 12.9's? The 2002 with the same mods will do it too,
Fred
BTW, don't the 2002 SS A4's come with 3.42 gears?
1994 Z28, A4,
BEST 1/4 MPH 110.49
BEST 60' 1.668
BEST 1/8 mph 86.77
Race Weight 3600lbs
24lb SVO inj's...
[This message has been edited by Fred94LT1 (edited September 12, 2002).]
Old Sep 13, 2002 | 08:32 PM
Post
Fred, the 00 went 12.9 in Feb. The 02 a4's come with 3.23's as a standard rear. The optional rear is a 3.42. Mine has a 3.23. The 02 m6's come with the 3.42. I just ran the 02 again on thurs night and got a best of 13.04 at 106.96 w/1.98 60'. The temp was about 50 degrees on thurs night. Needless to say, I think this car will go faster than the 00 once the miles are on it and the temps drop even further.
Ben
02 SS
Best 60': 2.032
[This message has been edited by brtrlyrdls1z28 (edited September 13, 2002).]
Old Sep 13, 2002 | 09:28 PM
Fred94LT1's Avatar
Wink
I find it amazing how the auto Z28's(1998-2002) seem to beat the 6 speed cars almost everytime in the qtr at a track. Ben, just imagine with a 3800 converter, 3,73's and a set of ET Streets. Can you say very low 12's,
Fred
1994 Z28, A4,
BEST 1/4 MPH 110.49
BEST 60' 1.668
BEST 1/8 mph 86.77
Race Weight 3600lbs
24lb SVO inj's...
Old Sep 14, 2002 | 03:57 PM
Post
Yeah...I've noticed that too. Autos always seem to qtr better. When I get a converter I have to be aware of the torque management system. I'm being told if it sences too much torque it'll retard my timing. This is separate from my traction control system which I'm able to turn off. The torque management system is programed into the computer and cannot be turned off. Unless I get LS1 edit or a lap top. The 98-02 cars all have this but the 02's are supposed to be more sensitive to it from what I'm hearing. I'm also hearing whether it's a 98-02 car, with the stock converter, I shouldn't have to worry about the torque management system activating until I change to a higher stall. I don't know if there's a way to tell if it's activating but personally I don't think I've noticed a problem with this in either car yet.
Fred, how are the new heads? They must have made a big difference.
Ben
02 SS
Best 1/4: 13.04 @ 106.96 w/1.989 60'
Best 60': 1.989
[This message has been edited by brtrlyrdls1z28 (edited September 14, 2002).]
Old Sep 14, 2002 | 07:16 PM
Fred94LT1's Avatar
Post
Unfortunately, the first run I made some of the pistons rings failed. I mean after the heads were installed. Yeah, 13.3@98 isn't what I expected. On a 1.8 60' time. I recorded 9 degrees of knock retard the whole trip. Next time at the track after my new rebuild I expect high 11's,
Fred
Old Sep 14, 2002 | 11:49 PM
Post
Wow Fred, sorry to hear that. Once it's fixed it'll be a huge difference. High 11's are definetly there. When you're ready to take it to the track, let me know.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
