First nitrous pass
First nitrous pass
Tried out the nitrous for the first time Sunday. With a 20-30 mph headwind the car was 2/10ths and 4 mph slower NA on my first run. 2nd run, hit the nitrous switch right after launching and had to back off for it to shift into 3rd. The car still ran a 11.44. I can't wait for a full nitrous run.
You should easily go 10's with the 150 hit with NA times you are running as long as the tranny holds. FWIW, set up for the bottle and in the summer my car runs 11.9@114.9 NA but runs 10.3's@129 on the 150 hit. I would think a 10.7 out of yours would be easy to attain spraying out of the hole and on a full pass.
Matt
Matt
Right now it's about a 120shot with a flat line 10/1 AF and a little less than 1000psi. I'm trying to sneak up on the 150 shot.
Matt
Matt
All the tracks around the area are now NHRA except for one.
It is all in the set up. I have a nitrous converter which is not that good for NA times. Gearing plays a major role too.
When I had the 4.10's in the car and 26" tall tires (still with a nitrous converter) I ran consistent 11.5's@118 with 1.60 60fts. in the summer heat with a best of 11.44 (see sig). I changed to 3.70 gears and a 28" tall tire and my times went to 11.9's@114 with a 1.75 60ft in similar weather. However, when I spray the 150 shot my gearing and converter are better matched and that is why I pick up 1.6 seconds and 15 mph. I would run out of gear with the 4.10's on the bottle.
The converter and car in general is set up for a 250 hit but I need a direct port to spray anything over 200 as I melt the rear 2 plugs due to distribution problems. I figure the car would probably go ~9.6-8.8@137-138 on the 250 hit.
Matt
I am jealous now of Z-Rated!
Here I lay sitting on my now SLOW Z as you play like a kid again. Congrats on a hot running car Rick! Figure out that shift deal and whack it!
Your car is simply awsome!
RUENUF
Mar 13, 2016 03:37 PM
