Expecting 12-flat E.T.'s --> What Driveshaft Do I Need?
Old Dec 1, 2002 | 07:56 AM
WickedZ's Avatar
Hey guys,
This spring I am expecting to pick things up a bit on the '95 and hopefully lower my ET with the addition of heads/cam combo. After both seeing these head/cam cars at the track and checking various boards & other resources, I'm not gonna set my sights too high and assume I'll probably be clicking ET's in the 12-flat range, especially since I'll probably continue to run on my RAM clutch/BFG Drags setup. The Moser 12-bolt is next w/4.11's, but what is my best best as far as driveshafts go? I could care less about weight...What will get the job done without expected breakage?
Thanks, Cheers!
Old Dec 1, 2002 | 10:18 AM
RacinLT1's Avatar
Im running a LS1 driveshaft in my low 11 sec car..........i know it's asking for trouble.......
If you want strong and a lifetime warranty,get a Denny's driveshaft. 1 of the best in the business,they sell for around 350-400.
Old Dec 1, 2002 | 11:39 AM
Stephen 87 IROC's Avatar
I ran a stock driveshaft deep into the 11's with no problems. I only invested in a new shaft when I added a transbrake to the transmission.
It's not the driveshaft that's the weak link but the small u-joints. Upgrade to a 3" x .083" steel shaft and change all the yokes to use 1350 series u-joints.
Old Dec 3, 2002 | 07:26 AM
Derrick Redd's Avatar
Near 10 second ET's with a stock steel driveshaft.
Old Dec 3, 2002 | 08:20 AM
justahoe's Avatar
Lightbulb
I'm trying to get a LPE aluminum ds gp going if you are interested. From what I've heard they are one of the best out there.
Old Dec 3, 2002 | 10:02 AM
kazman's Avatar
I've seen an aluminum one twist in half. I'm going back to steel this winter with a Spohn extreme with 1350 joints ($315).
Old Dec 3, 2002 | 11:18 AM
RobK's Avatar
I just saw an LS1 with the stock aluminum driveshaft turn into a pretzel a few weeks ago. It took out his new torque arm in the process. He was running in the 11's, running w/slicks.
Old Dec 3, 2002 | 01:12 PM
justahoe's Avatar
That is part of the problem. These guy get an ls1 aluminum ds and think it a great piece, its not. From what I've seen they are about like a pop can, not very strong. The LPE piece is much thicker and larger in dia then the ls1, the LPE is 3 1/2 where the ls1 is like 2 1/2 or 3 in. That's my .02
Old Dec 3, 2002 | 08:01 PM
Kyle@CSS's Avatar
11.16 in the 1/4 with my stock 94 Z28 driveshaft
Old Dec 6, 2002 | 07:56 AM
TRICK95's Avatar
Based on the info provided, I think I'm gonna stick with the one I have, I've already upgraded Ujoints twice, and until the Moser 12-bolt goes in, I'll stick it out. After that, Denny's Driveshaft is getting a call from me, as I'll probably make the move from BFG Drags to ET Streets.
Thanks for your help and info guys!
Old Dec 6, 2002 | 08:00 PM
96z's Avatar
96z
Comparably how strong is the 1LE shaft?
Old Dec 6, 2002 | 09:36 PM
justahoe's Avatar
Question
I don't know about the 1le for sure. I know they are around 2 3/4 in dia. But that is about all I can tell about them.
RUENUF
Mar 13, 2016 03:37 PM
drt
Sep 27, 2015 04:39 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
WPHIG2
Aug 27, 2015 06:37 AM
realistyc
Jul 28, 2015 07:32 PM
