ET Streets Coming! Rear End Gonna Last? Stall & Gears
Check out my mods listed in my sig..
Vigilante 2800 Stall
Bmr Lca's
3.73
Etc....
Well after running a best of low 14's in my car with major traction problems I have bought two extra rims and will Be ordering Et Streets soon. I think I can get into the mid to high 13's with slicks with ease. I am at 3800 elevation too! I run low 14's @ right about 97 MPH with ****ty *** 2.4xx or higher 60 foot times. The track improved the compund and every day getting better since they repaved it and rubber is being left down.
I am thinking the best was will be to launch at around 1000Rpms to 1200Rpm's because I really don't want to break the rear. I just want my times to drop good into the 13's. What good are my stall gears, etc.. without traction.
Is my Rear Going To Hold Up Though, and how should I launch to be easy on the rear? Any Advise?
Bmr Lca's
3.73
Etc....
I figure it will since a guy here with 350 RWHP Ls1 was running et streets and his laster 2 seasons of Hard HARD driving and 6K Clutch drops till it went boom. So then I will be ok babying it and being automatic.
I've cut quite a few 1.6's in the past few months on Nitto's and been fine. I just wore those out and moved to 10.5 ET Streets and went out to the track the other night. Got 4 passes in and the car felt fine.
They are a world of difference in "feel" compared to the Nitto.
I have run a ton of 1.6 60's and quite a few 1.5's with over 450rwhp so you should be fine. Javier how did your car run with those ET streets? I have heard they slowdown most 300-400rwhp cars a little bit like mph and a tenth ET? I would like to try a set of BFG's for some motor passes and see if I p/u et and mph. LMK later Clint
last weekend I cut 3 1.5 60 ft's and now my 10 bolt screams when you drive at normal speeds its a gonner, dont give your stock rear to much time either if your cutting a good 60. I have a 9 inch that will cure what ails it though!
Well with et streets I will not have to worry at all about traction, I know it will be their. I hear to many people with nitto's having bad days where they can't hook or having problems hooking up still. I have faith in my rear as long as I don't abuse the **** out of it. I also only go to the track maybe once or twice a month, now with tires I will probably go once every 2 weeks at least.
oldschool
Feb 9, 2016 09:21 PM
Not saying it couldn't happen though.
