drag radials and 60 ft times
Old 04-14-2007, 07:21 PM
fasteddie94's Avatar
It's a toss up for me right now. I'm looking at either getting Nittos or getting another set of BFGs. What kind of 60 times are you guys cutting on Nittos? It looks like I am going to be in the 1.8-1.9 range. I am looking for a consistent hook everytime ad the BFGs have been doing wel so far. I'm just tired of flinging every rock on the road into my quarter panel.
fasteddie94 is offline
Old 04-14-2007, 08:59 PM
94CamaroZ28's Avatar
DRs: MT ET Street Radials. There is NO substitute.
94CamaroZ28 is offline
Old 04-14-2007, 09:55 PM
CamaroSS30thAnn's Avatar
what he said
CamaroSS30thAnn is offline
Old 04-14-2007, 10:37 PM
Oh, and if you were asking what kinda short times you can see, we got guys doing 1.4 shorts on 'em.
Old 04-14-2007, 11:49 PM
Z-RATED94's Avatar
Iv'e cut a 1.75 on my Nittos with no track prep. But now that I layed out the bucks for some Bogarts I'm going with everyones favorite, MTs street radial. Any sticky tire is going to throw rocks by the way. My wifes Envoy has a chipped windshield, from my daughter following to close behind my car after we left the track one day.
Z-RATED94 is offline
Old 04-15-2007, 06:27 AM
Moderator
AL SS590 M6's Avatar
There are many substitutes. MTs are just the most popular which soesn't mean that they wirk the best. Hoosier just came out with a drag radial, M&H has one. Word is that the Hoosiers blow the MTs away for hook & consistancy. I'll report back later on that I'm trying them this year.
AL SS590 M6 is offline
Old 04-15-2007, 06:34 AM
Moderator
What type of usage does your car see??
Mostly drag?? MTs, Hoosiers, M&H
Mostly street?? Nittos
Nittos will hook on a good track with proper suspension set up and burn out and they will last for around 15,000 miles on the street.
The other stickier DRs will stick better even on marginal tracks and some aren't technically street legal even though they have a DOT number and will only last 4-6000 miles at best.
Old 04-15-2007, 08:24 AM
Mostly street use but I'll be at the track twice a month. MT's are out of the question. If I were going for a full on race tire then sure, but I'm not going to run those on the street. I'm not a total rookie here, I know they are an awesome radial that can handle some real power. To run those on the street for a somewhat daily driver is a waste IMO.
I'm trying to decide on a tire that I can run everyday and not worry about changing wheels when I go to the track. BFG's have worked for me in the past, but I was asking what a nitto could handle. I haven't seen first hand anybody push them to their limit.
The suspension is stock with LCA's and relo brackets. Other mods are intake, full exhaust, LS6 manifold and gears.
Old 04-15-2007, 08:27 AM
I understand that they will throw some rocks, but I am hoping a little less than my BFGs. It seems like every pebble in the road peppers my car.
Old 04-15-2007, 10:29 AM
once the tires are warm and sticky theres no avoiding it no matter what tire u have
Old 04-15-2007, 10:54 AM
AutoRoc's Avatar
1.85 on 275/40/17 Nittos
Bolt on TPI car with maybe 300lb-ft/225hp @ the wheels. Dead hook everytime.
1.80 on 315/35/17 Nittos @ 400lb-ft/300hp @ the wheels. Very inconsistant. Adding a 50 shot on top of this made 1st gear useless. Went to ET Streets.
AutoRoc is offline
Old 04-15-2007, 05:51 PM
Dave '97 Z28 M6's Avatar
... I'm trying to decide on a tire that I can run everyday and not worry about changing wheels when I go to the track....
You can buy a pair of salad shooters for dirt cheap, and throw on a set of whatever DR's you want. IMO, it's just like having all-season tires vs. dedicated summer/winter tires. The compromise tire (in your case) will be less than ideal for both street and strip.
Dave '97 Z28 M6 is offline
Old 04-15-2007, 07:24 PM
CamaroRacing12's Avatar
thats wat i do! 255/50/16's M/T ET Street Radials!!! i got em for $165 a tire... the salad shooters r pretty light actually...ecspecially compared to my 18inch chrome rims
CamaroRacing12 is offline
Old 04-17-2007, 09:10 AM
supragrl93's Avatar
WIth the BFG's, I was able to cut a quite a few 1.6's 60's on 17in rims the tires were 275's. So for daily driving and wanting to cut a good 60' then BFG's are the way to go. Nitto hasnt made anything I've liked in a while other than some of their meaty truck tires. The M/t et streets are pretty much slicks and not safe to drive on the road. I just used those this weekend on my 15in bogarts and they hooked just as good as my slicks.
supragrl93 is offline
Old 04-17-2007, 03:13 PM
Quick Reply: drag radials and 60 ft times
