Do these times look about right?
60' - 2.158
330' - 5.910
1/8 - 8.909 @ 82.47
1000' - 11.496
1/4 - 13.686 @ 103.17
1998 Z28 A4 with 80,000 miles. The car is completely stock right now and I was curious to know whether these times are about where they should be at. Also where can I improve and how?
330' - 5.910
1/8 - 8.909 @ 82.47
1000' - 11.496
I'm not positive what gears I've got. I do know that I'm running about 2000rpm's at 60mph, so I'm thinking 3.23's? I'd check to make sure but I can't right now because I'm at work.
Is that a bad 60' time? Or is it just something that could be better?
New times:
60' - 2.079
330' - 5.803
1/8 - 8.804 @ 82.66 mph
1000' - 11.381
1/4 - 13.562 @ 103.6
My tires are pretty worn so I think that can go down even more after I get some new ones.
60' - 2.079
330' - 5.803
1000' - 11.381
Looks good. That's exactly where I started at when I was stock. 13.5 @ 103 here also. If you're still not sure about your gears then check the drivers door. Open the drivers door and look at the white RPO sticker. One of the codes will be either GU2 or GU5.
GU2=2.73
GU5=3.23
But I'm guessing you have the 3.23's if you're running 2,000 rpm's @ 60 mph.
GU2=2.73
GU5=3.23
ChrisFrez
Feb 1, 2015 08:26 AM
