Do ET Streets need tubes?
Old Aug 22, 2003 | 09:50 AM
BBB's Avatar
BBB
Do I need tubes? I understand that if I run with rim screws it is necessary, but does the design of the ET allow it to be run tubeless.
BBB
Old Aug 22, 2003 | 12:37 PM
WheelmanZ28's Avatar
I have seen E.T. Streets that have leaked out air after sitting for not too long of a period of time. I would definitely tube them.
Old Aug 22, 2003 | 04:56 PM
96z's Avatar
96z
Alot of people dont...I would have to say from who Ive talked to more dont than do...check to see how much they spin on the rim before you screw them also....
Old Aug 22, 2003 | 07:25 PM
BBB's Avatar
BBB
Thanks, I will run them tubeless and see how they hold.
BBB
Old Aug 23, 2003 | 01:21 AM
JWINN's Avatar
WOW! Make sure your insurance is in effect!
Old Aug 24, 2003 | 12:11 AM
I've run both ET Streets and QTP's with rim screws and no tubes, and no problems.
Old Aug 24, 2003 | 01:24 AM
JWINN's Avatar
Here is answere from MT:
www.mickeythompsontires.com/tech_tube_tires.html
www.mickeythompsontires.com/faq_drag.html#faq8
All I can say is my ET Streets loose air and go flat. This is a very sift side wall tire.
Good Luck!
Old Aug 25, 2003 | 09:37 AM
Josh-'04 GTO's Avatar
I second Fred's success without tubes.
Old Aug 30, 2003 | 07:57 PM
ltlhomer's Avatar
I ran tubeless / screwless with no problems until I ran over a staple (how the heck did one get at the track I don't know). FWIW, it's been over a month and my one et street has not lost even 1 lb of air pressure! So I say go tubeless, and if you somehow spring a leak, you can always save the tire by using tubes and rim screws :-). G'luck.
Old Aug 31, 2003 | 01:27 PM
Releacez28's Avatar
re:tubeless
GMHTP's project car TGOW ran unmounted, tubeless et streets and didnt have any problems. I myself am going to try and run mine tubless. I would definately take it for a spin around your block or up the road before you go anywhere to see if you like it tubeless and it feels ok. A buddy of mine drove his mustang about an hour away to an industrial park for street racing on tubeless (unmounted) et streets.
Old Aug 31, 2003 | 02:07 PM
Derrick Redd's Avatar
I've ran both ET Streets and ET Drags tubeless without a problem.
Old Sep 1, 2003 | 10:15 AM
Joe Brodman's Avatar
GP Moderator
I run no tubes AND rim screws on my ET Streets, no problems. Roomate runs the same w/ his QTP's on his 69 Firebird, no problem. Another friend pulls 1.5 and I believe has dipped into the 1.4 60' range, again no tubes. Another guy we run w/ at the track, pulling 1.6-1.7 60' w/ a stick car (like me), another tubless guy.
I've seen it to be more of the exception to run with tubes. My tires seem to leak about 1psi a day, due to the rim screws and solid valve stems.
Old Sep 1, 2003 | 11:21 AM
TedH's Avatar
I run tubes and screws. I don't want the random flat, the intermittant air leak, the spinning on the rims. I also want to decrease the risk of anything bad happening at over 100mph. For me it is simple, just follow the manufacturers recommendations. The extra few bucks can't hurt.
Old Sep 1, 2003 | 01:41 PM
Releacez28's Avatar
Re:Tubes Vs. Tubeless
I think you pretty much said it all ted, that was a very good point. Um let me think,yah i might mount mine after all! (how did you do yesterday!?)
Old Sep 1, 2003 | 02:25 PM
TedH's Avatar
I ended up taking a 2000 Bonneville instead of the Camaro yesterday. I did terrible. Couldn't seem to launch the car effectively. ET's were 17.36 to 16.34 with no way to predict... Went out in second round. Fortunately the points leader went out in round one... Two points meets left, I need to go four more rounds than the leader to repeat...
