Degreeing a Torque Arm
Old Mar 26, 2003 | 08:00 PM
GS355's Avatar
First of all, I hope I put this in the right spot since I don't see a chasis or suspension section. I just bought a BMR trak pak. I know it is adjustable and I was wondering what degree Some of you guys with adjustables running to get the best traction. I also got the subframs and the lca to go with the TA. Any info would be great.
Thanks GS355
Old Mar 26, 2003 | 08:23 PM
SMOKNZ's Avatar
I run mine at -4 deg. Anything less and i don't get much traction, and i get a very nasty vibration right before the tires hook up. This is with a moser 9" with LCA relocation brackets set up as far down as they can go.
Bill
Old Mar 27, 2003 | 05:18 PM
gb95zconv's Avatar
-2 on the stock rear works well for me.
Old Mar 27, 2003 | 07:18 PM
GS355's Avatar
setting
I'm going to start off with -2 degree. Thats what they recommend starting with from BMR. I also have a Moser 9". Does it make that big Of a difference with the lca relocation brackets?
GS355
Old Mar 28, 2003 | 06:34 AM
I think this would have got better response on the "Drag Racing" forum... moving it there.
Old Mar 28, 2003 | 09:02 AM
Pro Stock John's Avatar
-2.5 over here and 1.48-1.50 off the footbrake so it's not hurting my 60 ft's.
I think -4 might blow u-joints?
Old Mar 28, 2003 | 03:38 PM
SMOKNZ's Avatar
One of my buddies runs greater than -4 and hasn't lost a u joint yet. Multiple drag passes and at least 2 years of MFBA Road Course events at Road America. It really isn't that steep.
Old Mar 28, 2003 | 03:44 PM
I was told by one of my chassis peeps that -4 or more is on the edge and most folks might not want to do that...
Old Mar 28, 2003 | 09:21 PM
AL SS590 M6's Avatar
Moderator
-2° on my stock rear
Old Mar 29, 2003 | 12:47 AM
yellow Z28's Avatar
-2 Is the most you will need to run, thats what i run and im getting 1.30 60's
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
realistyc
Jul 28, 2015 07:32 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
