cracked 12's.. timeslip inside
Old Oct 18, 2007 | 07:06 PM
nb 96 z's Avatar
1st time to the track since my cam install a year and a half ago.. Made two runs at Milan yesterday. How does everything look and where is there room for improvement? Mods in sig.
1st Run:
Reaction .4879
60ft 2.0700
330ft 5.5932
1/8 et 8.5361
1/8 mph 83.18
1000' et 11.0871
1000' mph 95.72
1/4 et 13.2369
1/4 mph 105.13
2nd Run:
Reaction .2491
60' 1.8430
330' 5.3001
1/8 et 8.2298
1/8 mph 83.34
1000' et 10.7828
1000' mph 97.00
1/4 et 12.9379
1/4 mph 104.90
Old Oct 18, 2007 | 10:55 PM
silverz28camaro's Avatar
wow you have the same 3.73-2800 stall setup as i do, only i pull 1.74 60' with 245 nittos.
try some free mods as i did if you haven't................remove front sway bar and front bumper support and relocate the battery to the rear. that will help alot with weight transfer....it did with mine......as far as room for improvement, just keep that 60' foot time down and consistent and the watch the 1/4 mile time drop.
if you can manage a 1.74 60' i bet you will see a 12.7x pass...
good luck
Old Oct 19, 2007 | 07:52 AM
AL SS590 M6's Avatar
Moderator
What tires did you run on?
Did you have the cutout open?
Old Oct 19, 2007 | 02:17 PM
nb 96 z's Avatar
Yes, the cut out was open and I ran mickey thompson street radials. (255/50/16) They are brand new and I barely did a burnout with them the 1st time and left off idle. I eased into the gas because that's how I've done it with street tires and didn't realize how well they hooked. The next pass I did about a 5 second burnout and left off idle but floored it and I hooked. I was running about 21 psi in the tires.
Old Oct 19, 2007 | 02:24 PM
danhr's Avatar
your da must suck b/c i run those times on a bolt on car... it seems like you had some tire slippage on your 1st run.
but everything seems right... you could get a little better 60' time and knock off another .1 off your 1/4 et.
what altitude are you at?
Old Oct 19, 2007 | 02:49 PM
nb 96 z's Avatar
837' I believe.
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
