A Couple of Runs, NA and Spray
Old May 14, 2005 | 09:21 PM
whontime's Avatar
Went to the track a couple of weeks ago, but I am just getting around to posting the results.
1994 Z28, M6
Stock Bottom End
LE Heads, 2.02/1.60 valves
227/233 XE Camshaft
1.6 Pro Mag RR's
Stock Unported Intake
Jet Hot LT's with True Duals
Moser 12 Bolt, 4.56 gears
Nitrous Works 175 shot plate setup
This is a full weight car that still has the front sway bar, stock shocks and springs etc.... running an 17" Torque Thrust II Wheels and MT 17" ET Street tires, which didn't hook very well at all probably due to the lack of a good sidewall on them.
Run 1 NA, Missed 3rd gear coasted through the lights
60ft- 1.74
1/8th mile- 8.26
MPH- 82.27
Run 2, 175 shot, with a 140lb passenger
60ft- 1.80
1/8 mile- 7.57
MPH- 98.28
The short time is killing me. I would think that my short time should be somewhere in the 1.50 range on nitrous. Oh well, I have a set of Bogart racing wheels on the way, the front sway bar is coming off and I may look into a set of HAL's for the front. Anyway, I am liking the trap speed, but I have to get the short time sorted out.
DirtyDaveW
Dec 1, 2016 05:37 PM
warmeck
Feb 5, 2015 11:04 AM
squarehead
Jan 15, 2015 07:02 PM
