Can't launch
Old Oct 7, 2005 | 01:04 AM
seawolf06's Avatar
Can't launch
I need help with my launch. I seem to get a little jumpy and either stall out or smoke the tires. I know I need practice, but is there a specific technique I can use as a starting point? (i.e. stage, rev to xxxx rpm, let off hard/ease into it) Mods are on my website.
Old Oct 7, 2005 | 01:05 AM
mattybz28's Avatar
Re: Can't launch
If you've got decent tires, should just be able to rev it up to 3k or so and just step off the pedal as if you were walking... a quick slip.
Don't side-step the clutch because that just leads to bad stuff happening, even with street radials.
Old Oct 7, 2005 | 01:08 AM
seawolf06's Avatar
Re: Can't launch
what does side-step mean? I've already killed one clutch by easing off when I was trying to smoke em.
Old Oct 7, 2005 | 01:12 AM
mattybz28's Avatar
Re: Can't launch
side-step is doing that.. just dumping the clutch. If you slip the clutch you'll be fine, and yeah practice makes perfect.
Old Oct 15, 2005 | 10:48 PM
curtg21's Avatar
Re: Can't launch
didn't read your mods but a set of MT drag radials for the track will help tremendously. My brother runs tens a lifts the the fronts with em.
Old Oct 16, 2005 | 11:36 PM
seawolf06's Avatar
Re: Can't launch
yeah, but drag radials would kill my rear end and this is my every day driver. i'm looking more for technique here rather than parts. thanks though.
Old Oct 17, 2005 | 11:37 AM
96flame's Avatar
Re: Can't launch
Practice makes perfect. Everyones car reacts differently and the track may not grip the same from day to day. It becomes a feel thing once you do it enough. Have fun.
Old Oct 20, 2005 | 10:45 AM
myfirst99Z28's Avatar
Re: Can't launch
Dude, just rev her up to about 3 and a 1/2 and then, dump the clutch. You'll be sure to launch, with a little spinage too maybe, but it won't fail.
Old Oct 20, 2005 | 12:28 PM
seawolf06's Avatar
Re: Can't launch
well the problem is that when I start spinning, I have a hard time stopping. When I went and ran the 14.3, all I did was bog big time because I wasn't revving at all. I'll be getting newer tires in the near future, but I want to hit the track up next week. I'll post the new times, and thanks for the advice.
Old Oct 22, 2005 | 03:01 PM
Jameslt1TA's Avatar
Re: Can't launch
If you want to launch good on street tires rev her up to 3 k or so and let the clutch half way out or so. You can mash the pedal and let the clutch out the rest of the way. This will hurt the clutch cause it is burning it up but it helps for a good launch.
Btw isnt sidestepping slipping the clutch? Thats what i always thought it was.
Old Oct 23, 2005 | 04:15 PM
Dave '97 Z28 M6's Avatar
Re: Can't launch
"Side-stepping" the clutch is the same as "popping" the clutch. You just take your foot right off (side-step) the clutch pedal, and the pedal "pops" up.
Old Oct 23, 2005 | 05:09 PM
Jameslt1TA's Avatar
Re: Can't launch
that makes since lol i need to quit listening to people all the time.
Daluchman1974
Sep 11, 2015 06:12 AM
Critter
Jul 13, 2015 05:51 PM
Injuneer
May 15, 2015 08:45 AM
mark0006
Dec 25, 2014 09:50 PM
