Can't launch
Can't launch
I need help with my launch. I seem to get a little jumpy and either stall out or smoke the tires. I know I need practice, but is there a specific technique I can use as a starting point? (i.e. stage, rev to xxxx rpm, let off hard/ease into it) Mods are on my website.
Re: Can't launch
If you've got decent tires, should just be able to rev it up to 3k or so and just step off the pedal as if you were walking... a quick slip.
Don't side-step the clutch because that just leads to bad stuff happening, even with street radials.
Re: Can't launch
Originally Posted by seawolf06
what does side-step mean? I've already killed one clutch by easing off when I was trying to smoke em.
Re: Can't launch
i'm looking more for technique here rather than parts. thanks though.
Re: Can't launch
well the problem is that when I start spinning, I have a hard time stopping. When I went and ran the 14.3, all I did was bog big time because I wasn't revving at all. I'll be getting newer tires in the near future, but I want to hit the track up next week. I'll post the new times, and thanks for the advice.
Re: Can't launch
If you want to launch good on street tires rev her up to 3 k or so and let the clutch half way out or so. You can mash the pedal and let the clutch out the rest of the way. This will hurt the clutch cause it is burning it up but it helps for a good launch.
Btw isnt sidestepping slipping the clutch? Thats what i always thought it was.
Re: Can't launch
Originally Posted by Dave '97 Z28 M6
"Side-stepping" the clutch is the same as "popping" the clutch. You just take your foot right off (side-step) the clutch pedal, and the pedal "pops" up.
mark0006
Dec 25, 2014 09:50 PM
