Calculating DA
Old Apr 27, 2006 | 03:41 PM
JakeRobb's Avatar
Super Moderator
Calculating DA
I'm not sure which forum this should be in. It seems to relate most directly to drag racing, so I picked this one. Apologies if I chose incorrectly.
I have a basic understanding of density altitude (what it means and why it's important).
What I want to know is this:
For those of you that determine and record the DA when you go racing, how do you go about measuring it? Is there a device I can buy that will just give me a DA readout, or do I need to bring a thermometer, altimeter, and barometer with me every time, and do the math?
Thanks!
Old Apr 27, 2006 | 11:48 PM
AL SS590 M6's Avatar
Moderator
Re: Calculating DA
Thanks!
I just bought a TAG Command Air. Google it and check it out. Spits out more weather info than I know what to do with and has a data base for four race cars.
Old Apr 28, 2006 | 08:18 AM
JakeRobb's Avatar
Super Moderator
Re: Calculating DA
That's a pretty cool device.
Old Apr 28, 2006 | 10:12 AM
Re: Calculating DA
http://www.csgnetwork.com/densaltcalc.html
Old Apr 28, 2006 | 08:05 PM
Stephen 87 IROC's Avatar
Re: Calculating DA
Just too much info to copy again. It's not a simple a+b+c formula but it can be calculated with programmable calculators or within a spreadsheet with nothing more than temperature, humidity, barometric pressure and track elevation.
http://drr.infopop.cc/groupee/forums...2/m/6991040212
There are other factors racers keep track of. Air density, vapor pressure and dew point can be just as inportant as density altitude.
As for a simple device to use as a basic weather station, look at buying a Kestrel 4000 handheld weather station. It will even tell you density altitude and wind speed. They're available on Ebay and normally sell for about $230
Nayr
Mar 3, 2023 08:34 PM
Flint78
Jun 21, 2015 01:28 PM
kosta
Jun 5, 2003 11:01 PM
neversummer
Feb 21, 2003 07:27 AM
stevil
13
Sep 24, 2002 11:31 AM
