Bfg drag radials
Old Nov 8, 2004 | 10:15 PM
Dexter's Avatar
Bfg drag radials
My ? is whats a good tire pressure to use at the drag strip with Bfg Drag Radials.
Old Nov 8, 2004 | 10:22 PM
Capn Pete's Avatar
Re: Bfg drag radials
I was running mine @ 25 or 30 psi (I think I started @ 30? ) and they hooked pretty good.....I was cutting mid-low 1.9xx 60' times. They slowed my speed down compared to running street tires though.....I think because they're "stickier" so they're sticking to the track the whole way?
Old Nov 9, 2004 | 05:32 AM
Raptor1's Avatar
Depends on your set up, mods, track prep, etc. The 60 ft. in my sig was with BFG DR's. I usually ran 18-20 psi in them and if the track was well prepped 22. Best results was when I did a real hot burn out.
Old Nov 9, 2004 | 06:09 PM
Paul @ Thunder's Avatar
It's just going to depend on what your set-up is and what your car likes. I ran them as low as 12 psi on my wife's Trans Am but usually right about 15-16 psi worked best. Went 1.59 60's with them so they did pretty good.
On another note: I saw some people this weekend at the Thunder Shootout going 1.4x 60' times with the new MT Drag Radials. Those things are bad!
RUENUF
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
