best way to adjust QA1's for drag strip?
Old 11-23-2011, 06:37 PM
  #16
mightymouse383's Avatar
Re: best way to adjust QA1's for drag strip?
Well when I run on funday sunday at our local track I will set the fronts to 1 and the rears to 6 and see what happens, last time I tried to launch @ 3500 RPM's I had to tow the car home...lol
mightymouse383 is offline
Old 11-24-2011, 11:19 AM
  #17
timelord's Avatar
Well then lauch at lower RPM to start with and increase until you blow the tires off,,,,
timelord is offline
Old 11-24-2011, 02:33 PM
  #18
I will try that and will keep u posted on how I do, thanks for all the advice.
Old 11-24-2011, 04:10 PM
  #19
timelord's Avatar
Good luck!!!!!
timelord is offline
Old 12-05-2011, 08:25 PM
  #20
Well I went to funday sunday and best pass I could get was a 12.90 @ 114 with a 2.1 60', I either spun or bogged on launch.
If I launched lower than 3000 rpm's it bogged and higher than 3000 it spun. I am ready to swap in a TH350 and a good converter to make the car consistent.
I have yet to get anything lower than a 2.1 60' and I am sick of it!!!!!!!!!
Old 12-09-2011, 04:23 PM
  #21
adam85's Avatar
Must have been burning those tires halfway down the track! With some traction could be high elevens given the mph.
adam85 is offline
Old 12-10-2011, 11:38 AM
  #22
The car bogged more then anything and when it started moving it was like a freight train, if I launched higher that 3000 rpm's it spun like crazy. I have already destroyed one 10 bolt rear which had 4.10 gears, now I have another 10 bolt with 3.42 gears and I think that the gear and the 28" DR is killing me out of the hole.
Old 05-14-2012, 08:06 AM
  #23
my1994z28's Avatar
I know this is a old post,but yes a 3.42 gear with a 28 inch tire is killing you,that is why you are bogging out of the hole..I would go with 3.73s or a 26 inch tire..I had the same problem 2yrs ago..I now have 3.73s and 26 inch tire and I am getting 1.42 60ft times..
my1994z28 is offline
Old 05-16-2012, 08:45 PM
  #24
Well I ran with the th350 installed and ran a 12.2 @ 114.45 with a 1.89 60'
I need slicks and I think I will be in the hight 11's
RUENUF
03-13-2016 03:37 PM
93 RedBird
11-15-2015 08:24 AM
95craz28
11
09-12-2015 07:47 AM
Daluchman1974
09-11-2015 06:12 AM
94ZinEdgewater
09-08-2015 09:55 PM
Quick Reply: best way to adjust QA1's for drag strip?
