Battery Relocation
Old Aug 14, 2003 | 07:57 PM
  #16
CANTONRACER's Avatar
My Optima red top weighs in @ 40 lbs.
Old Aug 15, 2003 | 07:53 AM
  #17
Ken95Z28's Avatar
JSK333 - On the output stud that goes to the internals of the alternator. There is a nut that attaches this stud to the alternator. That nut was loose and had to be tightened. If you can move the stud on the outside chances are it's loose.
Old Aug 16, 2003 | 12:28 AM
  #18
AL SS590 M6's Avatar
Moderator
Thanks for the link. How about the smaller one. I'm thinking track only battery.
Old Aug 17, 2003 | 10:50 AM
  #19
EDS Z28's Avatar
I am going to move my Optima to the back also. I purchased a BMR battery mount.
It will be installed with 1/0 gauge cable running between a remote starter solenoid and the starter. This way, this cable is only hot while cranking.
You also have to run 2-8 gauge wires from the back to the front, no biggie, these wires are not all that big. This way, when the kill switch is shut off, the engine will die without any possiblity of frying any of the electronics.
Here is where I got all the info:
http://www.2xtreme.net/~madmark/docu...ectswitch.html
Ed
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
weedog
Aug 15, 2015 08:23 PM
