Battery Cut-Off Switch
Old Dec 28, 2003 | 09:05 AM
Sean94Z's Avatar
I know if moving the battery to the rear of the car, you have to have a battery disconnect switch that will shut down the car when turned or pushed.
If you just have it disconnected to the battery, the alternator will keep the car running, so, I was thinking of connecting my fuel pump power wire to the switch also. Is this a bad idea?
I was thinking, if I am at the line staging and the tech turns it off, if I lose fuel, I Could go lean for that second and BAM there goes a few pistons .. Whaddya think?
--Sean
Old Dec 28, 2003 | 10:19 AM
RacinLT1's Avatar
wire the alternator into the kill switch. tech wants an immediate cutoff,and fuel pump wont kill the car quick enough.
Old Dec 28, 2003 | 10:56 AM
Stephen 87 IROC's Avatar
The car will stay running when the battery is disconnected because the alternator is feeding power back into the electrical system. You need to wire a relay in to disconnect the field wire from the alternator. When the field wire is disconnected the alternator doesn't produce electricity and the engine will shut down.
When you disconnect the battery, the fuel pump as well as every other electrical component is automatically disconnected. Once the alternator is isolated out so it doesn't feed the system, nothing electrical will operate when the battery is disconnected.
Old Dec 28, 2003 | 02:40 PM
sseeya's Avatar
Check out this set-up. I've got it on my race car and it works great. http://www.madelectrical.com/catalog/tm-1.shtml
With this set-up, the 1/0 cable routed forward to the STARTER is not “live,” except for during cranking. (No fire hazard as with other systems that have a “live” positive battery cable forward.)
Call and talk to Mark about his special system for NHRA Drag Racing & Main Disconnect Switch at the rear with Alternator.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
ducttape1975
Jul 10, 2015 06:29 PM
