ASR on or off
Old May 14, 2007 | 09:17 AM
NASCR46's Avatar
ASR on or off
With an automatic transmission car with the ASR option should you race it with the ASR on or off? Thanks
Old May 14, 2007 | 09:41 AM
The Engineer's Avatar
You must have the ASR "off" at the drag strip to achieve any degree of performance!
WD
Old May 14, 2007 | 11:12 AM
383Z4ME's Avatar
Wink
I forgot to turn it off once, before I had it permanently disabled, and I sat there doing a burnout at 1200 rpms with the pedal floored for about three seconds before I realized the problem. Everyone thought it was pretty funny except possibly me.
Old May 14, 2007 | 12:16 PM
NASCR46's Avatar
Thanks we'll know better next time.We turned a 13.25 @ 105MPH with it ON. Our mods are in the signature.What do you think we could run with the ASR off?
Old May 14, 2007 | 01:20 PM
383Z4ME's Avatar
Maybe 12.10 at 110ish
Old May 15, 2007 | 10:04 AM
NASCR46's Avatar
Ok thanks ,we hope to get to one of the local strips next week. Any launch ideas or techniques we should try?With an automatic do we want to let it shift through 3 gears or 4 gears?
Old May 15, 2007 | 10:12 AM
383Z4ME's Avatar
What stall?
What stall speed is your converter? The car should not get into 4th gear. If it's a regular shift pattern just put it in drive and let the trans shift. You can try leaving the line off idle the first run and then try running the idle up to about 1800 on the second run. If you have a stock converter you may only be able to idle it up to about 1500. You should not have to roll onto the throttle but instead mash it to the floor on the third yellow.
Old May 15, 2007 | 10:44 AM
NASCR46's Avatar
Thanks, it's a stock coverter.......So basically put the car in "D" not "D" with the square around it so it only shifts through 3 gears and then try brake torquing or not. (Suppose that's why it's called test and tune)We did have a PCM tune done on the car with the shift points maxed out.Bottom line is we just want to be faster than 13 seconds
Old May 15, 2007 | 10:50 AM
383Z4ME's Avatar
Yes
You got it!
Old May 15, 2007 | 11:01 AM
NASCR46's Avatar
Thanks for you help.I see your from Grand Rapids.We were at the Berger Show 2 years ago and at Superfest in Ypsilanti last year and again this year.
Old May 15, 2007 | 07:36 PM
skifast87's Avatar
holy crap you can pick up that much time?
Old May 16, 2007 | 08:10 AM
383Z4ME's Avatar
The ASR will pull timing like crazy when the tires slip. If he's making that kind of rwhp and can run 1.8x 60's he should be around 12.1x.
Old May 17, 2007 | 09:06 AM
skifast87's Avatar
Well you learn something new every day. I never knew it actually pulled timing. This would make a great deal of sense.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
dluna333
15
Mar 13, 2015 12:30 PM
1996LT1Z28
Jan 14, 2015 08:09 AM
