Anyone use these rims?
Old Jan 12, 2004 | 09:53 PM
cozmo's Avatar
I was looking around at rims on jegs and came across these. http://www.jegs.com/cgi-bin/ncommerc...05&prmenbr=361
They have them in 15x8 with 5.25" backspacing, so they should fit. I was just wondering if anyone knew. Basically I'm looking for a cheap set or rims for drag radials.
Old Jan 13, 2004 | 05:11 AM
rskrause's Avatar
Moderator
Re: Anyone use these rims?
Any 15" rim requires either a spacer or grinding the caliper for brake clearance.
Rich Krause
Old Jan 13, 2004 | 08:10 AM
Raptor1's Avatar
It's a steel wheel. It would be heavier than a stock aluminum wheel. If all you want is some spare wheels to mount DR's for a trip to the track, why not just buy a pair of used stock wheels? You can usually pick them up for $50-$75 ea.
Old Jan 13, 2004 | 06:55 PM
cozmo's Avatar
I just found out it weighs 27 pounds, so it is out of the question. Ideallly I would like to go with a 28" tire, thats why I didn't want stock rims.
Old Jan 14, 2004 | 05:12 AM
RacinLT1's Avatar
unless you havent listed all your mods,a 28" tire would be overkill.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
