Anyone think this trap/et is possible?
Old Jul 13, 2005 | 11:22 PM
  #16
blackztpi's Avatar
Re: Anyone think this trap/et is possible?
hate to be the party pooped here, but an le3 setup will the break an lt4 timing chain clear and clean. no chance at all of it living for any length of time. with that kind of power, you will need to run a cloyes double roller and electric water pump. you wont want to do this twice.
Old Jul 14, 2005 | 10:13 AM
  #17
WildThing94Z's Avatar
How many LT1 motors you see with 450+ using stock castings? All motor anyway...? Daily driver?
I know of one . . . in my driveway
Old Jul 14, 2005 | 10:15 AM
  #18
blackztpi's Avatar
i'm really stressing this info so u can hopefully make a better choice before putting te motor together
Old Jul 14, 2005 | 01:14 PM
  #19
96speed's Avatar
Originally Posted by robvas
How much did your 396 make
That setup is not gonna make 120mph, unless it has serious weight reduction. Monoblade, electric WP, and a solid roller and it would be no problem ~120-122mph.
Ryan
Old Jul 14, 2005 | 01:36 PM
  #20
Kraest's Avatar
Retired
A little over 520 on the engine dyno with locally-ported LT1 heads, LT1 intake manifold, and a conservative hydraulic roller, which is probably why it ran circles around most cars on the street and blew the tires apart at 60 mph @ 3870 lbs. That was over 3 years ago. Alot has changed since then. The same setup would make around 550hp if AI ported the heads.
I'd rather the potential of my stock-cubed LS1, honestly.
Mike
Old Jul 14, 2005 | 08:44 PM
  #21
ChrisUlrich's Avatar
Why do you say this? Everyone from CMS says otherwise... I think LE even said it'll hold, not sure if I asked him though? But I called CMS up and made that switch anyway, its freakin cheaper too!! I can get a brand new water pump/stronger timing set for less then JUST THE LT4 Timing Set!! haha
Anyway, so now that I have the power adder of the Electric Water Pump... haha
What are the et/trap guestimates of a 383 LE3 setup in a full trimmed out 6 Speed 96 WS6?
Old Jul 19, 2005 | 03:33 PM
  #22
Add on to the list... BBK 58mm TB and Fully Ported Intake by Lloyd (Along with LE3 heads/cam). Anyone want to take a shot now? :-)
Old Jul 24, 2005 | 07:39 PM
  #23
Anyone got average numbers for a LE2 383 setup?
Old Jul 26, 2005 | 07:53 PM
  #24
Quickshotkimber's Avatar
Somebody better tell Joe this. He's been running low 9s with a stock LT1 timing chain for a while now with around 600rwhp.
Old Jul 26, 2005 | 07:56 PM
  #25
Originally Posted by ChrisUlrich
LE3 383 setup... stock T56/10 Bolt
Eagle Rotating Assembly
Splayed 4 bolt, the goods on the machine work
LE3 Heads/Cam setup up top
Fully ported intake
11.8 : 1 Compression
STOCK Throttle Body
STOCK gears
STOCK driveshaft
STOCK water pump
STOCK opti
LT4 Timing Chain
37lbs Injectors
Mail in Tune from Ion
Trying to nail a 120mph trap in the 1/4 on DR's... maybe a 11.8 or so.
Oh yea... also hoping for 415rwhp/400rwtq
Need the 58mm TB. I would have much higher expectations.
Old Jul 26, 2005 | 09:03 PM
  #26
And also the guys from cms... they told the LT4 would have absolutely no problems either...
I did get the 58mm tb. Just got it, and Lloyd is now fully porting out the intake. So only thing i'm missing are the 4:10's and 12 bolt.
Old Jul 26, 2005 | 10:00 PM
  #27
blackztpi's Avatar
biggest problem with big power and an lt4 chain is the water pump drive gear. a lot of people have problems eating up that drive gear. i don't see how its possible to run a stock timing chain on a 9 second car, but whatever i guess
Old Jul 28, 2005 | 04:52 PM
  #28
haha... oh well. I went electric and Coyles anyway. Anymore opinions?
Old Aug 5, 2005 | 02:35 AM
  #29
Victory Racing's Avatar
Yeah I've got an opinion for ya.
Old Aug 5, 2005 | 06:10 PM
  #30
Yea Bullsh!t... what do you know about my motor? hahahaha
