Anyone think this trap/et is possible?
Old Jul 12, 2005 | 09:38 PM
ChrisUlrich's Avatar
LE3 383 setup... stock T56/10 Bolt
Eagle Rotating Assembly
Splayed 4 bolt, the goods on the machine work
LE3 Heads/Cam setup up top
Fully ported intake
11.8 : 1 Compression
STOCK Throttle Body
STOCK gears
STOCK driveshaft
STOCK water pump
STOCK opti
LT4 Timing Chain
37lbs Injectors
Mail in Tune from Ion
Trying to nail a 120mph trap in the 1/4 on DR's... maybe a 11.8 or so.
Oh yea... also hoping for 415rwhp/400rwtq
Old Jul 12, 2005 | 11:07 PM
zx1216's Avatar
Re: Anyone think this trap/et is possible?
that motor isn't going to like the stock throttle body, my buddy with a le2 383 was pulling vacume through a tpis 52 mm so he went with the monoblade. Your going to want to go with a 58mm unit to optimize that setup.
Old Jul 12, 2005 | 11:09 PM
madwolf's Avatar
ET possible with traction and luck, traps probably not. (most likely around 118)
Old Jul 13, 2005 | 12:16 PM
I am gonna go with a 58mm tb... just not right away due to the financial part of things. I am also going with 4:10's in the rear.
Old Jul 13, 2005 | 12:22 PM
RedIrocZ-28's Avatar
We have a guy over on Michiganspeed.com, Al Fox, thats running a H/C/E (346ci) LS1 into the low 11's @ 118 I believe.
Exact times: 1.501 short time, 11.299 @ 118.59mph. A4 346ci LS1 with H/C/E. Good luck, I think with a LOT of tuning and getting your 60' down with a nice big 4000+ stall you'll see your 120mph traps.
Old Jul 13, 2005 | 12:27 PM
TedH's Avatar
Too many variables but it should be possible.
Old Jul 13, 2005 | 12:46 PM
M6 here...
I know they're many variables and i'm not hoping to get EXACT numbers. But just looking to get close to those numbers. I want to be able to take any stock Viper n/a (I'll be spraying 200 shot). If not a Viper from a dig because of traction issues and breaking crap, then maybe a roll. Just want to beat it one way or another. haha
I just want mid 11's with a 120trap. Prediction from a few is actually 430rwhp with similar with a nasty torque curve. But thats with the tb gears.
Old Jul 13, 2005 | 01:07 PM
oops skipped the T56 part. Just launch the bastard at 5000 rpm. But make sure you have a Ford 9" under there.
Old Jul 13, 2005 | 01:23 PM
Kraest's Avatar
Retired
I'd hope for much more rwhp/rwtq than that with ported heads and a 383.
Mike
Old Jul 13, 2005 | 03:46 PM
TedH's Avatar
I should add, in all fairness, that although there are people who have gotten away with such a setup on the stock rear... For every person who posts about how they spend a day running 1.5 sixty foot times, most of us break things when we try to launch with a stroker becasue of the significant amount of torque a stroked engine usually delivers.
I know I spun my transmission the very first run after my stroker was installed.
I do have a 12 bolt because every 400 passes it would break on my old internally stock motor, just like clockwork. I installed the 12 bolt prior to the stroker and have not had a problem since.
I also went to 28" tires which slowed down my sixty foot times. to keep me mostly over the 12.00 cutoff for street class at most tracks.
I know this should be in the drag race forum but perhaps some folks will chime in who don't visit the drag race forum very often.... I will move it in awhile....
Old Jul 13, 2005 | 04:42 PM
97WS6SCharged's Avatar
Mike
Why is that? 430 rwhp is right around 505 hp at the flywheel. That's roughly 1.3 hp/CID, which isn't too shabby for any street motor.
Old Jul 13, 2005 | 05:01 PM
Kraest's Avatar
Retired
Actually, 505hp is more like 445+ through a 6-speed and 10-bolt.
I'd be mad if my stroker didn't make at least 450rwhp with heavily worked LT1 heads/intake.
Mike
Old Jul 13, 2005 | 05:34 PM
sniffin94's Avatar
I highly doubt you will make it without some serious suspension work ie, lca,s subframes, hals, tq ar.. I learned that valuable lesson when I was cutting 2.2 60's on the bottle.
Old Jul 13, 2005 | 06:32 PM
Mike
Depends on what driveline loss figure you look at. I usually do 15%. Ultimately it doesn't matter if it makes 350 or 450 at the tires, as long as it runs the number.
Old Jul 13, 2005 | 09:53 PM
How many LT1 motors you see with 450+ using stock castings? All motor anyway...? Daily driver?
Lloyd said that hitting 430rwhp shouldn't be to much of a problem with all the supporting mods... i'll be missing the throttle body and gears for now. But they WILL be installed, just not right away because I STILL have to get the exhaust and all that crap... oh man.
Just want to wail on any stock Viper n/a and hoping that 430rwhp and similar torque and a minty fresh torque curve would get me what I need to nail mid high 11's and close to 120mph traps.
