Anybody using 28" tires on stock susp 10 bolt?
Old Dec 31, 2008 | 11:58 AM
blown94's Avatar
wondering how well 28" tires will fit in a stock suspended 10 bolt 4th gen? Ive got a set of 15 x 8's but the backspacing i believe is only 4.75. Will they fit the wheel opening or would I need the full 5.5 backspacing?
Old Dec 31, 2008 | 10:37 PM
Depends on the 28's. I ran Hoosier QTP 28x11.5-15's with the only problem being having to move the axle back about 1/4" when the front surface of the tread started hitting the metal at the front of the wheel well, when trap speeds went over 125mph. Yet a set of 28x10.5-15W ET Drags required removing about 1" off the leading edge of the rubber bumper cover. The ET Drags seemed to grow more. That was with a "stock suspended" 12-bolt, but I don't think the difference between a 10-bolt and a 12-bolt will affect whether the tires fit in the wheel wells.
The 8" wide wheel with 4.75" BS will move the outside edge of the tire out about 3/4" farther than this:
Old Jan 1, 2009 | 03:43 AM
AL SS590 M6's Avatar
Moderator
I run twentyeght'' drag radals stoc suspended 12 bolt wth no fender mods at all because they don't grow.
Old Jan 4, 2009 | 10:49 AM
jakesz28's Avatar
I ran some on a 15x8 with a 5.5 backspace. I will be one to say not all slicks are the same. My M/T grew alot and I had to move the rearend back and they still rubbed the front and the bumper needed trimmed. I've seen other people run hoosiers and they did not rub.
I had them on the ten bolt until I killed it with 1.48 60' times leaving on 200hp with a cam only longblock. You will most likely need adjustable LCA's if you currently don't have them.
Old Jan 21, 2009 | 10:48 PM
1996camaroSSclone's Avatar
Im running 28s and for me the adjustable lca's was a must have to get them to fit. My axle was to far forward to fit on stock susp.
HectorM52
Jul 30, 2017 11:46 AM
InfernalVortex
Jan 17, 2015 09:35 AM
ddr698
Jan 9, 2015 10:05 AM
Catmaigne
Dec 25, 2014 12:16 PM
