Adding Hal QA1's and K-member!
Old Mar 9, 2004 | 01:36 PM
T/A lt1's Avatar
I broke the main caps in my LT1 so while I am putting a steel crank, h-beam rods, new low tension rings and a new cam I will also be adding a BMR K-memeber with solid mounts and a set of Hal's. Last time the car was at the track I had a problem with spinning and it may have had a little to do with track prep but the best I got was a couple 1.66 60's and the worst was 1.69. The car has run quicker 60's than that before with less power so I know it was spinning. How much could the extra weight off the front and the addition of adjustable struts really help? I am hoping lower 1.5's on motor and 1.4's on N2o what do you guys think? Later Clint
Old Mar 10, 2004 | 09:31 AM
95Bird's Avatar
I think that you should be able to get that 60' down with your new mods. The front raising quicker will have the most affect on it and the lighter weight that it has to lift is always a good thing.
Old Mar 10, 2004 | 09:44 AM
Chris'SS #2152's Avatar
Sorry to hear about the breakage but that 60' should come down with your new mods. I am getting ready for sim. mods myself and hope to get down there also with my 60'
Old Mar 12, 2004 | 08:21 AM
T/A lt1's Avatar
I hope it works guys b/c I have a few things done already but it really never hooks up hard. I have relocation brackets, poly bushings in boxed in rear control arms, removed front swaybar and a RR airbag@18-21psi. The best I have done is 1.58 on the gas and spinning. Thanks Later Clint
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
marlar98
Sep 19, 2015 07:53 AM
RX Speed Works
Sep 11, 2015 03:31 PM
