To AC or not to AC...that is the question........
Old Aug 19, 2002 | 11:45 PM
  #16
speedmiser's Avatar
Post
Wicked - Thanks for the #
Old Aug 21, 2002 | 01:02 PM
  #17
Red_94Formula's Avatar
Post
how did you get only 30 pounds? every one says its close to weighing 60 pounds.
Old Aug 21, 2002 | 01:17 PM
  #18
Wicked's Avatar
Post
No clue, I was a little disapointed. I removed the AC Condensor, AC Compressor, and lines to the firewall. I even held all of the bolts that held stuff on. And it all came in at 30lbs.
Am I missing anything? I just unscrewed the lines out of the box by the computer.
Jason
Plates: "Stock 95"
1995 Firebird Formula
O'ring/4bolt 383, GTP Race Ported AFR 210s, Yank TH400, Yank 3800 Stall, Trans Break, Moser 12 Bolt w/ 3.73s, and the usual stuff like Hooker Long Tubes, Holley 58mm TB, Sphon Torque Arm, etc....
Old Aug 21, 2002 | 04:11 PM
  #19
KTamez's Avatar
Post
Sounds like you missed the all the equipment thats still sitting in the dash. Yank out that complete plastic box (You will need to make a new firewal plate to cover up the hole).
This is the only picture I could find handy (LS1 Car):
http://www.madmanandcoracing.com/redcamaro/redcam4.jpg
THAT will give ya some room to work with!
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
Old Aug 21, 2002 | 10:12 PM
  #20
Wicked's Avatar
Post
Humm.. I'd like to do that but I want to maintain my heat. Can I still remove some stuff and maintain a heater?
Jason
Plates: "Stock 95"
Old Aug 22, 2002 | 01:02 AM
  #21
fawwaz78's Avatar
Post
any one have pictures of how to remove the A/C, i really need to get rid of it, its just i have no clue what to pull out and what not..
if there is any website that would be really helpfull..
thanx....
Old Aug 22, 2002 | 10:29 AM
  #22
Wicked's Avatar
Post
It's pretty simple, just pull out everything that you see is attached to your AC. All they way up to the black box.
Also, I must say I LOVE the amount of room I have under my hood now! Droping the Radiator and fans in was super easy!
Jason
Plates: "Stock 95"
Old Aug 31, 2002 | 01:21 AM
  #23
fawwaz78's Avatar
Post
Wicked.. what size belt did u use after the AC delet..
i have UD pullies too, i donr know if u do too or not..
thanx...
Old Aug 31, 2002 | 04:57 PM
  #24
Wicked's Avatar
Post
I used the same belt that I used with the AC in place. With the AC delete pulley it puts everything back the way it should be.
Jason
Plates: "Stock 95"
Old Sep 1, 2002 | 12:38 AM
  #25
fawwaz78's Avatar
Post
ok thanx for the reply man..
just one more question hopefully
what size belt u used? cuz i used my old belt which was 59inch 6 ribs, and it was too long.. and someone now told me that they used a 58inch 5 ribs, would that work?
and what the different between 5 and 6 ribs?
thanx man......
Old Jul 4, 2003 | 02:15 AM
  #26
wildboar's Avatar
anyone have a used ac delete pully.. I know this thread is pretty old.. but I'm lookin for one around 30
Old Jul 5, 2003 | 01:59 PM
  #27
96LT14u2Nv's Avatar
i have also been considering this same thing. the delima continues, i still dont know what to do.
Old Jul 5, 2003 | 04:15 PM
  #28
97bowtie's Avatar
Those who say A/C is for wimps really should come drive around in AZ.
Old Jul 7, 2003 | 01:28 AM
  #29
gearhead3's Avatar
I can use it if it is still available.
roadhog420
Feb 7, 2003 09:33 AM
