4.10 Guys Inside
Old Jul 31, 2004 | 11:39 AM
slayer6x6's Avatar
4.10 Guys Inside
I just got the 4.10s in my car. My question is that when I go to the track do you think I should dump the clutch in 1st and then shift into 2nd to heat the tires up. Or do you think that I will be allright dumping the clutch in 2nd with the added torque of the new gears. What do you guys do?
Old Jul 31, 2004 | 12:47 PM
Josh'95Z28conv's Avatar
Re: 4.10 Guys Inside
I still use 1st. Just rev it up a bit and hold it. I use to use 2nd, but if there isnt plenty of water it can be hard on things. 1st still works great though.
Old Jul 31, 2004 | 10:57 PM
red's Avatar
red
I have always used 2nd. If you have a linelock you should have no problems weather there is water or not. Just bring up the RPM's some and dump the clutch.
Old Aug 1, 2004 | 04:12 PM
MetallicTrans96's Avatar
Throw'r in second and put on a show
Old Aug 5, 2004 | 11:07 PM
JoeliusZ28's Avatar
being that many m6's with 4.10s bark the 1-2 shift pretty good (mine included) youd think you would be ok dumping it in 2nd. But thats something ill never try because breaking the tires loose at a roll is much less of a jump compared to doing the same thing at stop. But if you got crappy tires and waterbox, you should be cool, but I dont think you can say it wont be hard on anything. Whatever you do, make sure you pre-load the drivetrain, cause its shock that usually hurts things.
Old Aug 6, 2004 | 07:09 PM
simple's Avatar
its gonna break at some point bet on that!
i dont get the whole 2nd gear burnout thing, 1st works fine for me!
preloading the the drivetrain without a linelock is a near impossible task with a stick
rev it up with the ball of your foot/shoe holding the clutch pedal down while your heel is on the floor board, then pivot off your heel to the left to release the clutch while mashing the gas
do the oppostie side of the clutch pedal (outside of your foot) to stab at the break for a burnout
Magenta_Hearts
Mar 25, 2015 10:24 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
cmdeshon
Dec 27, 2014 10:06 AM
Red97LT1
Aug 7, 2002 05:45 PM
