26x11.5x16 E.T. vs. 26x10.5x16's
Old Jan 25, 2004 | 03:58 PM
95 Mystic TA's Avatar
Question 26x11.5x16 E.T. vs. 26x10.5x16's
I was originally looking for a set of used 26x11.5x16 E.T. streets until today a guy on a local board offered to sell me his
26x10.5x16's for $200 already mounted.
First how much if any difference will there be in traction on a stall/geared bolt-on car?
Second are these tires worth $200 with the wheels?
Pic 1
Pic 2
Seller claims they had about 15 runs before he got them and he put 6 on them. I've only had exprience with Nittos so forgive me for the dumb questions and I thank you for viewing this thread.
Old Jan 25, 2004 | 04:12 PM
amean94ta's Avatar
i would never buy used tires in the first place but the best size is 28x10.5r16
Old Jan 25, 2004 | 05:29 PM
rskrause's Avatar
Moderator
How do you figure that a narrower tire is better than a woder one?
Rich Krause
Old Jan 25, 2004 | 06:25 PM
amean94ta's Avatar
i meant 28x11.5 r16 i was just waking up when i posted that being that its the tallest widest slick you can get
Old Jan 26, 2004 | 12:20 AM
Serene's Avatar
uh.....taller != better
taller will cut down your gear ratio
Old Jan 26, 2004 | 03:47 AM
Gold Z's Avatar
The 26x10.5x16 is the correct fit for an 8" wide wheel. The 26x11.5x16 is designed for a wider wheel. It will fit on an 8" wheel but the tread doesn't lay completely flat.
Old Jan 26, 2004 | 06:56 AM
Projectz28's Avatar
Moderator
In my experience wider is always better. But alot of it will have to depend on the set up in your car. If you are set up for drag racing and wont have suspension issues, then the 10.5 wors quite well on a 8" rim. My best times and 60' times were on 26x10.5's. Now I have a 26x11.5 and the times have gone down hill, but thats partley to blame on the new gear selection.
In your case... Id stick to the wider is better theory and get the 11.5's. More rubber on the ground is always better IMO.
BTW, a 28" tire is not the "best". its only best if your set up to use it.
Old Jan 27, 2004 | 08:38 AM
amean94ta's Avatar
\perfect for us guys running 4:56's
NewsBot
Jul 3, 2015 02:10 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
NewIn95
Middle Atlantic
Oct 17, 2002 01:47 PM
