13.9
Old Aug 6, 2007 | 04:52 PM
95 WHITE TRANS's Avatar
13.9
Hi i was wondering if a 13.9 102 mph is a good time with my mod's.They are slp shortie headers,slp cat back,3,42,mad wolf tune,ram air induction.By the way my car is an a4.
THANKS
Old Aug 6, 2007 | 05:06 PM
Z-RATED94's Avatar
More info would be nice. What was the weather like? DA? 60 ft times? Street tires or stickys?
Old Aug 6, 2007 | 05:10 PM
bombebomb's Avatar
From what you told us, I dont think them are bad times, but im no expert.
Old Aug 6, 2007 | 05:15 PM
The weather was on the humid side .Tires are f1 gs d3 and 60 foot 2.00.
Old Aug 6, 2007 | 05:18 PM
Z-RATED94's Avatar
Not bad then. But if you want to wake that car up, put in a quality converter and get a set of sticky tires.
Old Aug 6, 2007 | 05:20 PM
Would a high flow cat help?
Old Aug 6, 2007 | 05:25 PM
Z-RATED94's Avatar
Not really, unless yours is clogged.
Old Aug 6, 2007 | 05:40 PM
Thank you for the response you have been a great help.
Old Aug 7, 2007 | 11:43 AM
TedH's Avatar
My '94 ran 13.5-13.6 consistently at 101 in decent air with Edelbrock shortie headers, drag radials, and Moroso cold air as a comparrision, however it was a M6 with a Hurst short throw shifter. I suspect a higher stall converter would put you in the same range or perhaps a little better as you have a faster MPH than I did.
Old Aug 7, 2007 | 06:34 PM
How much would drag radials help?
Old Aug 7, 2007 | 07:13 PM
danhr's Avatar
You have a lot more left in it. You should be able to cut a 13.5 or 13.4 out of it. Your mph is up there. 60' time is sharty.... work on launching your car better. an a4 likes to dead hook, no spinnage. a quality set of lca's would be the next mod to do if I were you.
Old Aug 9, 2007 | 10:36 AM
93Phoenix's Avatar
That's one weird time, my buddy Z28 with nearly identical mods ran 13.7 @ 102 w/ a 2.1 60'
Old Aug 9, 2007 | 12:17 PM
TedH's Avatar
Stuff happens. My ET can vary as much as .5 between July and October and the sixty foot times will be similiar. There are an incredible amount of variables to take into consideration on each pass to accurately quanity the details of the timeslip.
Old Aug 9, 2007 | 01:44 PM
mn96ss's Avatar
My time in sig backs this statement up. And I have 3.23s. You should hit around a 13.2 with your trap speed with a GOOD converter and DRs.
Old Aug 9, 2007 | 02:42 PM
What's so weird with a .2 difference?
