10.5 or 11.5 ET streets?
Old Apr 6, 2004 | 08:27 PM
94 CAMRO Z28's Avatar
Going to be mounted on stock sized rim. I know the 11.5 will fit but is it a bit of overkill? If I really dont need it and I can save a little bit of $$ and weight with the 10.5 I would rather go that route. Let me know what you think. Thanks
Aaron
Old Apr 6, 2004 | 08:39 PM
97WRAITH's Avatar
I would go with the 11.5 because the 10.5 don't look right.
Rob.
Old Apr 6, 2004 | 09:03 PM
Grover's Avatar
Go with the 11.5's, they are only a few $$'s more and give you a bigger contact patch.
Old Apr 6, 2004 | 09:11 PM
96formulaLT1's Avatar
10.5's will be fine. once you heat em up they'll be plenty sticky.
Old Apr 6, 2004 | 09:13 PM
rskrause's Avatar
Moderator
Definitely 11.5.
Rich Krause
Old Apr 6, 2004 | 09:33 PM
SkAchilles's Avatar
10.5s will be more than enough, but the 11.5s look a lot better The only reason I got the 11.5s is because I got a good deal on them, 10.5 is all you really need. Never get more tire than you need, its just drag(not much, but it adds up)
Old Apr 7, 2004 | 07:35 AM
HungryT/A's Avatar
It is always better to overtire a car!
Old Apr 7, 2004 | 07:51 AM
Derrick Redd's Avatar
11.5's
Old Apr 7, 2004 | 07:53 AM
LWM's Avatar
LWM
If your on stock rims, 16 x 8", I think, I'd be inclined to go with the 10.5 wide tire, the stock tires were 245's were they not?? The 10.5 ET tires work out to be 266's or there abouts.
I think if you put 11.5 tires (292's) on an 8" rim you would have some cornering issues.
Just my .02 worth.
Hope this helps
LWM
Old Apr 7, 2004 | 07:56 AM
badblackta's Avatar
I have 10.5s and they do just fine for me. The 11.5s do provide a larger contact patch on the road, but that is just more rolling resistance. If you are running a bolt-on set up right now then you could just go with the 10.5s, and when you do more you could get the 11.5s if you think you need them. Either one will make you hook though
Old Apr 7, 2004 | 06:45 PM
Well right now the car is bolt ons with a hotcam. Soon im going to heads, larger cam, and LTs. For suspension work I have bmr lcas, relocation brackets, and a rear air bag.
Aaron
Old Apr 7, 2004 | 09:33 PM
BPS's Avatar
BPS
I'm assuming you have an M6 with that ripper - i don't see a 12 bolt in your sig.
ET streets + M6 = 12 bolt
11.5 on a stock sized rim I think is a poor match - although 11.5 looks nice under the car - I'd stay with the 10.5
11.5 is also marginally more rotating mass putting pressure on the rear
my $0.02
Old Apr 7, 2004 | 11:11 PM
RED95LT1Z28's Avatar
I have the 10.5 on my car and they look fine
Old Apr 7, 2004 | 11:16 PM
IrocSS85's Avatar
get the 11.5s now and be done w/it.
Old Apr 7, 2004 | 11:17 PM
'93 formy ...'s Avatar
26x 11.5 or 16" ZR1 style rims
