10 to 12 bolt
10 to 12 bolt
I was thinking about changing to a 12 bolt.What made you guys do it.I'm a little worried about adding some serious mods because of the rearend,I don't want to dig myself in a ditch because I have to spend the 2 grand on the rearend after I bought a (no specific order) TC,cam,heads,draglites and most likely slicks.What order should I go about doing this.
Looking at the history of autos at the track, you are probably safe until you hit the track with ET streets or better.
Ryan
since u are an auto guy, i would not be too worried at this point. i have seen many auto LT1 guys run low 12's on the stock rear end with like 1.6 60' times. dont worry about it yet. mabey invest after u start running mid to low 12's but for now, u are fine.
My original rear has held up very well so far. I just got back from a day of testing and a new best 1.49 60' time. I will be switching from that to a Strange Eng 12 bolt as soon as it arrives, any day now actually. /My reason for changing has more to do with my going from a 28" bias slick to a 30" radial slick. The taller slick needs a 5.13 gear instead of the 4.56 the 7-1/2" one has now.
Of course the extra strength is an added bonus!
What kind of mods do you have and what horsepower do you produce,so you had no problems running slicks on a stock rearend.I was thinking a cam or tc first,but in what order should I do it.I will probably go with a hotcam cause of emissions I want to go bigger but I don't want to fail,and a 3200 stall tc.
I started from the rear and worked my way forward on my car.
Moser 12-bolt & driveshaft, then TH400 and 383. If you get a big converter, you'll break the stock rear. Seemed like common sense to me.
As far as what's been done to the 305 motor goes, that isn't info that will ever be put out for general discussion.
I would do the cam and converter and then see what it does. Likely you will find it'll want more rear gear and get the set that goes with the largest tire you can run. The 4.56 is good with a 10.5 x 28 ET Drags.
Run what you have until it breaks, then consider upgrading to a 12 bolt or 9".
I swapped out my 10 bolt to a 9" when I finally installed a transbrake in the car. I didn't thing the 10 bolt would take more than one hit off the transbrake.
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
