1.796 60' with BFG DR and full suspension?
So I went to the local 1/8 mile track Friday and the best 60' time I could cut was a 1.796. This is with 315/30/18 BFG drag radials(not the best for traction) but still. I have a bolt on 96 LT1 that put down 263 hp and 268 torque through a built tranny with a 2800 stall and a 12 bolt with 4.11 gears. I've also got a full suspension that should be set up for maximum traction although I haven't checked the pinion angle since the 12 bolt went in.. The car is also lowered 1 1/4" and the LCA's are set to the top hole in the relocation brackets.
My best run was a 8.419 at 81.92 mph with a 1.796 60'. I did a decent burnout with about 15psi in the tires and most of the runs I was still spinning all the way through 1st. Race weight should be right around 3560 lbs.
So are my tires limiting me or is that about the best 60' I can get without adding power? I can tell on my last run that it hooked up pretty damn well, but I don't if I was still spinning a little or not.
here are some things hurting you
lowered
low on h.p.
tire/wheel combo
with that gear I bet your driving out of the power range
LCA not set up right.
heavy
Pinion angle is off from being lowered
I'm sure there is alot more too, so I would be pretty happy with the numbers you put down considering the set up of the car....... If you car is lowered etc. and on 18's its obvious you don't want an all out drag car, and thats fine. You just can't expect max performance out of it.
lowered
low on h.p.
tire/wheel combo
heavy
lowered
low on h.p.
tire/wheel combo
heavy
lowered
low on h.p.
tire/wheel combo
heavy
Also I know 18's won't hook up well compared to 15's, but I just want to make sure there is nothing else causing traction problems.
As far as the gears, I purchased the rear end as advertised with a 3.73 gear, so the 4.11's were quite a surprise.
I wouldn't think the pinion angle would be off too much since I had it adjusted properly with he 10 bolt and the torque arm wasn't moved for the 12 bolt install.
Also I want to get everything set up for the new motor combo so I know I'll have 1 less thing to worry about later.
I just wanted to get some base runs in while I can since last Friday was my only Friday night off until around September.
If they're spinning at all, the tires are hurting you.
I'm impressed at the ET myself. That's like 12.80's @ 106 mph roughly in the 1/4. I'd always work with what you have first. Check the pinion and set it at 2-3 degrees negative. Drop the lca a hole or two. I think that tire should hook up with that amount of power and good suspension parts doing their job. Goodluck!
As stated above, a 3500 stall and 15" M/T Drag Radial tires on some stock rims would make things move out better and also be more consistant.
I'm impressed at the ET myself. That's like 12.80's @ 106 mph roughly in the 1/4. I'd always work with what you have first. Check the pinion and set it at 2-3 degrees negative. Drop the lca a hole or two. I think that tire should hook up with that amount of power and good suspension parts doing their job. Goodluck!As stated above, a 3500 stall and 15" M/T Drag Radial tires on some stock rims would make things move out better and also be more consistant.
Were supposed to be racing tomorrow. If I hook up, I'm pretty sure I'll take him since hes still got 2.73's. I thought a 3600 would be too high with a bolt on LT1, but everyone says it'll be just about right. I figure with the LT1's stout low end torque the 2800 would have the advantage.
I'm saying with my new motor combination going in this winter it should have a higher stall because of the increased hp. That's why I didn't get to carried away with the stall speed.
I also raced the guy with the 3600 stall and I spun through 1st and half of 2nd and still beat him by at least a couple cars. I know he'll pick to some in the tune, probably 15-20hp, but I think his 2.73's are really holding him back.
Nostang 96z
Sep 14, 2002 08:22 PM
