1/4 ET's going from 2.73 to 3.73
Old Feb 18, 2004 | 02:19 PM
Don't Look Back's Avatar
Hey guys, I am currently running 13.9's with my mods (sig) and 2.73's. I'm planning on putting in 3.73's before the season starts in 2 weeks. Assuming traction, and a flawless run, what kind of gain can I look for? Thanks.
Old Feb 18, 2004 | 03:11 PM
WS Sick's Avatar
If you can pull a good 1.9 or lower you'll gain at least 2 or 3 tenths and a few mph.
Old Feb 18, 2004 | 03:54 PM
JustaLT1's Avatar
I went from 13.98 to 13.62 switching from 2.73's to 3.73's. My mph picked up 1 or 2 mph, but it was mostly ET that I gained. My 60' dropped to high 1.9's from mid to high 2.0's. I just ran Nitto drag radials and never spun. Definately worth the swap. Good luck!
Old Feb 18, 2004 | 05:21 PM
Thanks for the replies, on a side note, if any of you guys are running 3.73's in an A4, what do you tach when cruising on the highway (70-80MPH)?
Old Feb 18, 2004 | 06:29 PM
JustaLT1's Avatar
I generally run about 3,000 rpms at 80 mph.
Old Feb 19, 2004 | 01:08 AM
Robert95z's Avatar
i gain 2.5 tenths and almost 2 full mph
Old Feb 19, 2004 | 11:50 AM
Steve Y's Avatar
More like 2700 rpm at 80.
Old Feb 19, 2004 | 12:00 PM
firepheasent's Avatar
I gained the same thing!
Old Feb 19, 2004 | 01:12 PM
DB75's Avatar
3,000 at 80 mph
2,600 at 70 mph
Old Feb 19, 2004 | 02:21 PM
Steve Y's Avatar
Originally posted by Hellion
3,000 at 80 mph
2,600 at 70 mph
Try this: http://www.f-body.org/gears/ It does not agree.
Old Feb 19, 2004 | 05:23 PM
JustaLT1's Avatar
Why don't you try and listen to someone who has 3.73s in an A4 and knows what they're talking about? I don't care what that link says....I know what RPMS I'm turning at 80 mph. You don't Mr. Knowitall.
Old Feb 19, 2004 | 06:12 PM
Steve Y's Avatar
The link is right, you are wrong. Deal with it. Maybe your tach or speedo is off. Maybe you don't have a .70 o.d. gear or 3.73 rear end gearing.
Old Feb 19, 2004 | 07:04 PM
JustaLT1's Avatar
Dude, I have a stock A4 transmission AND 3.73 gears and I've had my speedo recalibrated. Funny how someone else with an auto and 3.73s has said the same thing I have....yet no one has agreed with you. Perhaps if you actually HAD the setup that was being talked about...your argument might hold some water. But you're pointing to a calculator on the internet saying that you are right. This is the same calculator that says I should be doing 117 in 3rd gear at 5700 rpms. WRONG! Now go sit in the corner, dumbass.
Quote from the calculator's site:
Welcome to my Gear/MPH Calculator. This program will be improved over time, but for now it's not really much past Gamma. It's all JavaScript, and based on an Excel spreadsheet somebody sent me a while back.
Old Feb 20, 2004 | 09:05 AM
GUMP's Avatar
Maybe you should include tire diameter in your comparisons?
Daren
Old Feb 20, 2004 | 09:15 AM
DB75's Avatar
I hear ya JustaLT1. This guy has an answer for everything. He doesn't even drive an f-body. Hey Steve Y, I think you need to spend more of your time over at the Corral.
