Would a reprogram help
Old May 19, 2004 | 08:07 PM
md1's Avatar
md1
I have a 1994 Z28 with M6 and 150,000 Miles that I have only had for 3 months . It runs great after a new opt-spark, coil, water pump, wires, plugs, 24 lb SVO injectors, intake gasket, LT4 knock sensor and descreening of the MAF meter. Like I said the car runs great just dose not have the bottom end I was hoping. I only run 93 octane and was wondering if a tune by someone like pcmforless would help?
Old May 20, 2004 | 11:28 AM
97Z-M6's Avatar
yes becuse the svo injectors are rated at a lower psi, and when you put them in our car they are acctually a bit bigger than 24 becuase of the higher fuel pressure. that doesnt sound like a whole lot but when your talking about a injector thats pulse widths are measure in milli seconds. thats alot.
and put the screen back in becuse it helps straight the air flow in the maf for a more accurate mesurement.
Aug 7, 2015 08:52 AM
HCz28
Feb 15, 2015 03:01 PM
Rod Bender
Jan 3, 2015 03:15 PM
555PREZ
Pacific
15
Feb 1, 2003 01:08 AM
steelheart
Dec 8, 2002 02:10 AM
