Will I need a special cable to use this?
Old Oct 13, 2003 | 09:57 PM
95 z28 noob's Avatar
Wanting to purchase an autoxray scan tool. The one I am looking at is the Autoxray EZ-Read 2000. Since I have a 1995 Z28 and it has the OBDI computer but the OBDII connecting terminal will this unit work. Please, anyone with experience with this answer this post so I can order one or keep looking. Here is a link to the one I am interested in.
http://store.yahoo.com/levineauto/autez20codre.html
Thanks,
Eddie
Old Oct 13, 2003 | 10:57 PM
InjectedSS's Avatar
Re: Will I need a special cable to use this?
Thanks,
Eddie
YEA that kit will work. I have the same one. The cable that you will be using is the BLUE one which is listed as the "OBD-II MFG Specific Cable"
Old Oct 13, 2003 | 11:38 PM
Thank you! Glad it will work, looks like a nice unit. Gonna order one tomorrow.
Much appreciated,
Eddie
Old Oct 16, 2003 | 11:26 PM
ok, got the scan tool today, plugged it in and got a code............................have no friggin idea where to look up the meaning of the code and searching the net showed most codes as 4 digit. I think mine was a 2 digit code but I could be wrong. I will have to do it again tomorrow to be sure but it said electrical. Is there an easy and convenient way to look up trouble codes. Not just for F-bodies but for other vehicles as well?
I will try to get the exact trouble code tomorrow but I am almost positive it wasn't 4 digits.
Eddie
Old Oct 16, 2003 | 11:50 PM
madwolf's Avatar
The 4 digit codes are OBDII codes. OBDI codes are 2 digit.
If you do a search, I'm pretty sure you'll find its meaning, or you could always post here or PM me and I'll let you know what is it.
Old Oct 17, 2003 | 08:20 AM
Thanks for the reply. I will rescan it today if/when I get time and see exactly what the code was. I think the code has something to do with the fans. It only comes on when the fans are operating. If the fan goes off so does the SES light. I will get the exact number of the code again and do a search or post in here for answer.
Eddie
Old Oct 17, 2003 | 09:10 AM
GetaZforgetGT's Avatar
Here's a link to a page with 94-95 Trouble codes.
http://www.carprogrammer.com/Z28/PCM...95_LT1_DTC.txt
Old Oct 17, 2003 | 09:39 AM
ok, code was 29 if i did it correctly which by your link above shows this:
Code29 - Secondary Air Injection (AIR) Pump Circuit
Now I have to find out what that is, hehehe
Thanks,
Eddie
marlar98
Sep 19, 2015 07:53 AM
Louey
Pacific
Sep 1, 2015 07:19 PM
Aug 24, 2015 06:41 AM
Aug 5, 2015 08:35 AM
