Will Datamaster work with Windows XP??
Just like the title says. I got a new laptop and just picked up a Belkin fu105 adapter for the cable I got. But when I went to download the Datamaster it says that it needs windows 95 or 98 to run. Said nothing about XP.
thanks guys.
thanks guys.
win xp
it worked on mine without a problem
if it doesnt work you allways can use compatibility mode feature of windows xp
i have all sorts of old win 98 progs working mint with compatibiliy mode
cool. You used Tunercat with thte Datamaster? I notice that your car has almost the same specs as mine. Except for one minor think....the KILLER HP!!! How do you get so good numbers?? Did you clock it yet???
hp
um my power comes from
1: decent head porting
2: hotcam
3: 12.5:1 compression on 94 octane
4: longtubes and open cutout
5: 58mm tb
the list goes on but these are the big things.
oh even thou tunercat and datamaster are great the bigest improvement would be a dyno tune with a wideband Ii made 35hp and 40ft lbs more after my dyno tune thanks to a felow member.
2: hotcam
5: 58mm tb
