Wideband O2 PCM hookup and logging
Old Jul 17, 2006 | 11:10 PM
  #16
jonathan_abilene's Avatar
Re: Wideband O2 PCM hookup and logging
i dont know, why dont you check ebay?
Old Jul 18, 2006 | 06:36 AM
  #17
SBCGENII's Avatar
They are a decent price in summit look in there.
Old Jul 18, 2006 | 09:03 AM
  #18
Buttercup's Avatar
The simple add-on box for RPM capture to the LM1 is $100. The AuxBox is $250 but allows more extensive logging.
If my A/C input spreadsheet works, it's $0
Old Jul 18, 2006 | 09:10 AM
  #19
Sweetred95ta's Avatar
Very true. That would cut a lot of money out of logging a/f with a wideband setup. Would all I need would be the wideband O2 and the cable to take it to the A/C pressure switch, or do you need the converter box too and then take that to the pressure switch?
Would this work?
http://cgi.ebay.com/ebaymotors/Innov...06190961QQrdZ1
I was just thinking too. I bet you could have someone on here take that AC pressure signal, input your equation (patch), and make it log like that in the actual program. I think his name is Matchstick or something.
Old Jul 18, 2006 | 09:20 AM
  #20
Buttercup's Avatar
My LM1 came with a pigtail to make your own wiring harness. It already does two analog outputs that are totally configurable for 0-5 volts. One output I use to emulate the stock O2 sensor (0-1V) and the other one I configure 0-5 volts for a certain AFR range. So the basic LM1 kit comes with everything you need. You do have to solder a couple lengths of wire onto the included pigtail to suit your needs.
Of course you also need good datalogging software but if you're serious about tuning you'll already have this
Hopefully I hear back from some people on my spreadsheet. I'm hoping it's effective!
Edit: that LC-1 you list should be all you need if my little tool works as hoped
Old Jul 18, 2006 | 09:24 AM
  #21
That guy's name is StickMaster and he posted in your other thread. If you get it to work, he can patch FreeScan.
Old Jul 18, 2006 | 09:28 AM
  #22
Buttercup's Avatar
He has my spreadsheet! The only thing that'll be missing if he does that is the ability to change the resolution. That might be a concern. If the numbers are hardcoded into Freescan you'll have to configure your wideband output exactly to spec. With my spreadsheet you can input your AFR and voltage range.
I need some real testing work put into this whole idea. It should all work great in theory but we don't know until the experiments are complete.
Old Jul 18, 2006 | 09:51 AM
  #23
Well, for us fbody guys, we don't want to see anything below 11:1 or above 15:1, so why can't you make the range that small and that should make the resolution a little smaller? Would it be hard to configure the wideband on 0-5V to cover this range? Maybe this is not a good idea, but I understand what you're talking about.
Old Jul 18, 2006 | 09:55 AM
  #24
Buttercup's Avatar
That's exactly what I'm doing in the spreadsheet. If he wants to add a specific range into Freescan that'd be fine just so long as the person knows to configure their wideband accordingly. That would suck for those guys who don't have a programmable output though. I also don't know what kind of resolution is truly necessary. Maybe it's a big help, maybe not. I just don't have any testing time put into this thing. That's why I offered it up to anybody who wants to try... who knows when I'll have the time again
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
