Wideband O2 location
Old Apr 14, 2011 | 03:16 AM
  #16
ray396's Avatar
Cool Re: Wideband O2 location
Hi, I have a hollowed out cat in place, I put the sensor right after the cat. It has been working out very good. I am still tuning, it helps alot.Ray
Old Apr 14, 2011 | 05:16 AM
  #17
The disadvantage of locating the wide-band sensor after the "Y" is that you don't know how each bank of the engine is running, and that's the way the PCM controls the fueling - by individual, independant banks. You could have one bank running rich, and one bank running lean, and you would never know it because the sensor is reading the combined exhaust of two banks.
Old Apr 14, 2011 | 12:47 PM
  #18
MTL_Z28's Avatar
Ok I see so Injuneer would you recommend putting a bung/plug in each collector then and this way you can log and tune with info from both sides?
I have a Innovate LC-1 btw don't know if this makes a difference.
Old Apr 14, 2011 | 05:21 PM
  #19
Originally Posted by Injuneer
I'd put a bung in each branch of the Y-pipe. That way you can swap the sensor, and measure each bank independantly, which is the way the PCM controls the engine.
Or get a dual-sensor unit.
http://www.rpmoutlet.com/mt.htm
http://www.altronicsinc.com/pages/o2alert.html
http://www.innovatemotorsports.com/products/kits.php
I answered that above.
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
Henson071
Aug 4, 2015 09:32 AM
